Read more...
malachi wrote:Thanks for the kind words.
(snippage)
Ken - There is a reason behind my putting the temp stability data in the appendix. All that matters is what is in the cup - and I trust those results.
IMAWriter wrote: (snippage)
While I believe I understand Ken's questioning of temp stability from idle, or shot to shot, valid as it may be ( I deal with temperature issues as an Anita owner) I appreciate your answer that "what's in the cup" is, for YOU (and me) the final word. If we take it to it's conclusion, my guess is that if the 1st pull from, say 1-2 hours idle...the normal amount of "rest' between pulls for us home espresso folk...is as good as the 2nd pull, then it would make sense that indeed the GS3 is maintaining a solid temp as seen on the read-out...+ or- the stated limits.
Ken Fox wrote:Rob,I just want to clarify, for the umpteenth time, that I'm not speaking as someone who is convinced that tight temperature control is essential to great shotmaking. This is a VERY OPEN question to me at this point in time. I personally think that you probably can make great shots without tight temperature control, but then what do I know?
You know plenty...I always enjoy your lazer-like wit and wisdom ;>DThe point that I am making is that claims are being made for this machine and others that assume that tight temperature control is being obtained. By tight temperature control I am not addressing whether this machine can settle down into some stable repeatable shot profile and temperature during a long shot run. What I am addressing is whether you can walk up to this machine after a random idle period and get a shot at the temperature you are asking the machine to make the shot at. Can you then bump the intended shot temp up by 0.3 degrees F, and reasonably expect that the shot will in fact be delivered to you at a temperature of 0.3 degrees F higher than before? What is the error band in shot temps that are delivered vs. what is requested on the input panel? If the error is ± 0.7 degrees F and you ask for 0.3F more or less, then what exactly are you actually getting in your cup?
According to Chris, an uncommonly good shot of espresso
Does any of this make sense?
Am I just spewing out hot air that no one else thinks is worth considering?
Ken Fox wrote:If one is making claims about tasting minor brew temp differences based on simply telling the machine to change the shot temperature by these tiny increments, but has not tested whether the machine CAN REALLY DO THIS, than it is really not proven that your observations are due to actual small delivered shot temperature differences because you don't know if the machine is really delivering the ordered shot temps.
Does any of this make sense? Am I just spewing out hot air that no one else thinks is worth considering?
ken
Ken Fox wrote:I just want to clarify, for the umpteenth time, that I'm not speaking as someone who is convinced that tight temperature control is essential to great shotmaking.
Nick wrote:The key part of your statement here is "great shotmaking." What's "great?" It all hangs on the answer to that question, doesn't it?
Ken Fox wrote:I guess everyone has his own definition. For me, it would be a shot that grabbed my attention, something that was absolutely phenomenal, in the same league as one of the best wines you've ever drunk, or like a terrific shot you remember from an outstanding cafe.
What's yours?
ken
