Hi Karl,
This is enlightening to me. Based on this thread as well as this one:
http://www.home-barista.com/forums/graduating-to-e61-t341.html, I have decided to step up my detergent backflushing intervals. So far I have done it at 3-4 week intervals and I have noticed some off-taste towards the end of this interval. There is also quite a bit of "gunk" that comes out after the backflush. So, going forward, I will be detergent backflushing at 1-2 week intervals depending on use.
I think sheygetz's comment below makes sense and I'd rather do some re-lubrication than put up with an off-taste and compromise the cleanliness and perhaps even the durability of the machine.
sheygetz wrote:I remember discussing the pros & cons of lever vs solenoid operated E61s with quite a few knowledgeable people here in D. I was told more than once that backflushing (the purpose of which is to remove oils/ grease etc.) over time reduces the lubrication of the lever, and that as a consequence you'd have to re-grease the moving parts of the lever every now & then. So, to me the phenomenon you describe comes as no surprise. (I don't remember which kinda grease - and the name would prolly mean naught your side - but it definitely was grease, not oil.)
In terms of the backflushing procedure itself, I let PF stay in for about half a minute after the first detergent backflush and then do another one without removing PF. After this I take the PF off, rinse it clean, put it back in and do another backflush. I repeat this until the water both in the blind filter and coming out from below the group into the drip tray is clear. If I understand correctly, you do not rinse the PF/blind filter during the process? Again, I'd be interested in hearing thoughts from others on what would be "best practice" here...
Btw, I see cannonfodder has written a nice article on machine cleaning for the SwagFest...
Br,
Teme
