BobS wrote:Just a guess, but you may have a broken part or spring. Besides the great internal pictures here, there
is a detailed - How to rebuild the E61 group, at - http://coffeetime.wikidot.com/e61-group-servicing
My guess is all you'll need to do is remove the lever and the lower assembly, then get the parts you need.
Beware that the generic rebuild kit that folks like Espressoparts offers may or may not work. I found
most of the gaskets correct, except the mushroom O-ring, which was too thick for my Andreja and the
springs were significantly different.
Still, it seems you may need a few more parts, but without disassembly it's an unknown at this time. The
great thing is the E61 head is pretty easy to take apart and put back together.
Bob
BobS wrote:You'll probably have to buy individual parts. But several of the sponsers would have parts. Stefano's has a tea parts page at - http://espressocare.com/
Select: Parts --> Isomac --> Tea
Bob
mp wrote:I noticed no liquid coming out of the pressure relief valve. I did about 5 or 6 pulls ... and still no pressure relief like when I did the first couple of backflushes.
HB wrote:For the benefit of those who are wondering what these valves look like, a few diagrams from Lino. Please do not copy these images.
The first image shows the E61 lever at the rest position. The two lower valves are open to allow the brew chamber and expansion chamber to drain. The uppermost valve is closed. Water from the HX circulates through the upper port on the left, passes alongside the "mushroom" to heat the grouphead; as the water cools it descends through the lower port on the left. The temperature difference creates a thermosyphon that circulates water between the boiler and grouphead.
The next image shows the E61 lever at the mid position. The two lower valves are closed and the upper valve is barely open. If this pump has line pressure, water will flow through the upper port, grouphead cap and screen, gicleur (yellow), descend towards the brew chamber (orange cam), and finally through the L-shaped channel to the brewhead. It's easy to see the purpose of the Allen screw (gray); it caps the hole drilled during manufacturing for the first leg of the channel.
The final image shows the E61 lever in the brew position. The upper valve is held open by the orange cam. The valve at the bottom of the expansion chamber is held tightly closed by a spring. The spring above it holding the second valve closed is weaker; it will open at about 4 bars of pressure. It only takes a second or two for the brew chamber containing the orange cam to pressurize. As the pressure builds, water eeks pass the valve below the orange cam, allowing the pressure to drop. This action is the novelty claim of the E61 patent since the pressure is automatically lower as the expansion chamber fills. Once the lower chamber fills, the pressure equalizes in all chambers and the valve below the cam closes.
The familiar "whoosh" that follows the lever being lowered is water evacuating the brew chamber and expansion chamber. Again at rest, the expansion chamber and brew chamber are empty. Water continues to circulate along the jacket of the uppermost chamber as the thermosyphon re-establishes itself.
mp wrote:So you also suggest that fixing this problem would require a disassembly and replacement of all seals etc.
mp wrote:The coils and back mounting plate is not in Stefano's kit ... does it matter ... should they need to be replaced while the group is apart? Also the group head gaskets seem to come in three sizes 8mm, 8.5mm, and 9mm. Wasn't the whole idea that the E61 was supposed to be using standard parts? What size does the Tea ll need?
HB wrote:No, I don't think this has anything to do with failing seals; their symptom of failure is a constant drip drip drip. Remove the lower expansion chamber to determine why the exhaust valve isn't being pushed open. Take photos as you proceed should you need a reminder of the reassembly steps.
mp wrote:So please let me verify what you are saying ... I do not need to replace any seals. I just take apart the lower portion of the E61 group and this is the part that contains the lower expansion chamber?
mp wrote:After pulling a shot this morning I noticed that the pucks are left wet ... would this be a cause of that also?
HB wrote:Yes.
mp wrote:the arrow is pointing at what I believe to be the bottom of the E61 group which I have to disassemble ... is that correct?
stefano65 wrote:my guess is that your grouphead not only is completely gunk out with coffee but the 2 square spindles are not square anymore and they developed and edge
of course mine is just a guess
mhoy wrote:Post some pictures of what's inside for better advice.
BTW: Won't oils become rancid? I'd suggest ordering some food grade grease. Or perhaps one of the members of HB in your area can give you some.
Mark
