Pressurestats and NSF compliance: Barksdale, Sirai, Jaeger, et al ?
Link to "Pressurestats and NSF compliance: Barksdale, Sirai, Jaeger, et al ?"by timo888 on Fri May 11, 2007 8:01 am
I admire the know-how of many of the H-B regulars. From H-B member Eric S I've learned that the ailing pstat on my recently acquired 1976 Oly Club should be replaced with one that has heavy-duty connectors because on my machine the pstat controls the heating element directly. Now, if I had a clue how to wire up an SSR, an alternative would be to use a less capable pstat, like the CEME or MA-TER, and have the SSR control the heating element.
I have begun to look around H-B.com and the web at large for more information on pstats. I can't find the Jaeger website, and the Sirai website has lots of 404 Page Not Found and Javascript element errors. On the Barksdale website, one of the first things that came to my attention was this: some of their pressure switches are described as being NSF-approved while others are not.
Regarding their E1S and E1H models, for example, Barksdale wrote:NSF approvals make these pressure switches an ideal choice for pressure control in demanding food and beverage applications.
What is known about the NSF-compliance of the more popular pstat upgrades?
Regards
Timo
timo888
Link to "Pressurestats and NSF compliance: Barksdale, Sirai, Jaeger, et al ?"by jesawdy on Fri May 11, 2007 10:10 am
FYI - Here's a link to a PDF on Jaeger Regulation pressure stats (I found this awhile back):
http://www.controldistributions.c...ure%20Switches.pdf
The manufacturer website is http://www.jaegercontrols.com/ but it is funked up...
Jeff Sawdy
jesawdy
Link to "Pressurestats and NSF compliance: Barksdale, Sirai, Jaeger, et al ?"by timo888 on Fri May 11, 2007 7:51 pm
I sent an email to engineering support at Barksdale and asked for a recommendation for an espresso boiler, and the reply I received suggested model 7000 732F, but with the proviso that the maximum operating temperature of the switch is 180°F :!: When I followed up, the tech suggested the switch be used with a cooling loop (though the Barksdale FAQ says only the diaphragm-style switches are appropriate for steam applications).
Regards
Timo
timo888
Link to "Pressurestats and NSF compliance: Barksdale, Sirai, Jaeger, et al ?"by timo888 on Fri May 11, 2007 8:11 pm
timo888
Return to Espresso Machines
