by cannonfodder on Wed Apr 05, 2006 8:34 pm
Quick update. I just looked up the spec on the regulator. It is a Watts P50. According to Grainger,
Water Pressure Regulator,1/4 In,300 PSI
Water Pressure Regulator, 1/4 In Female Inlet/Outlet, Shut Off 40 PSI, Max Operating Pressure 300 PSI, Gauge Port FNPT 1/4 In, Max Temp 150 F, Diaphragm, Disc And Seal Are Rubber And Consist Of FDA Grade Elastomers, Thermoplastic Body Material, For Use In OEM And Irrigation Applications To Regulate Pressure In Systems That Require A Constant Downstream And Accurate Flow Performance, Features A Bottom Clean Out Plug For Service, Height 3 In, Width 1 9/16 In
Correct me if I am wrong, but that looks like the regulator tops out at 40PSI, but has a max input of 300psi. I do have some pretty beefy water pressure, but it is not over 300psi. I will remove the clean out plug and check it for scale
Suggestions, please.....
