OK, now for the Silvia pressure modification. This proved much more difficult. The recommendation found linked on this site was to purchase a second brass washer and add it to the system to reduce pressure. But I read a post that said when this was attempted the pressure went way low. And the part seems to be hard to find. On my machine, at least, the fitting was angled way down and was a real bear to remove. It was on really, really tight and I was worried about breaking something. However, supporting the fitting as the nut was turned (with a big wrench) finally did the job. Unlike the Eliane OPV, this one is not adjustable. Backing out on the nut almost immediately produced leaking.
The solution was to purchase some fiber gasket material and cut out a washer. You can see in the photo that the outside is preety crude (an octagon, I didn't bother to round it. Surprisingly, even though the gasket is much thicker than the original copper washer, I still couldn't get the pressure down to 10. So I took the spring out and filled it down like I did with the spring on the Eliane OPV. And even then I had to add the original copper washer back into the system. I also put two winding of teflon tape on the threads to minimize the chance of leaking. With this set up I was able to adjust the pressure up and down without any leaking, and make dynamic adjustments while the PF with the gauge (shown in the first posting on this topic) was in place. I set the pressure at 9.75 bar on the assumption that the actual brew pressure would be a little less as it was on the Eliane. Of course, without a built in gauge I couldn't test that, but the coffee tastes great!! Here are two photos that show the pressure mod:
In the first you can easily see both the homemade fiber washer and the original copper washer. In the second, you can also see the SSR (relay) mounted on the side wall. (I'll discuss the PID in another posting).
One other suggestion, learned after wasting time: don't remove the hose clamp and plastic hose from the pressure release fitting as recommended in the earlier link. It's a pain to get back on, at least on my machine with the fitting angled way down. Instead, remove the other end from the water tank, push it back into the boiler chamber, and just untwist it as you unscrew the fitting or put the fitting back on. When you're down just push it back through the side opening and up and over into the water tank again.
The pressure mods on both machines are inexpensive and non-technical. The only real cost (for the Silvia) is the PF with gauge, and I suppose one can be borrowed if the $35 hurts too much. By making these mods, an important variable is controlled and one potential strike against the Silvia is removed. The tool for adjusting pressure on the Eliane was really overkill--it's not so hard to remove the cover and make the adjustment. In the case of the Silvia, once teflon tape is applied to the threads and moderately compressible gasket material is used, the adjustment is easy through the open top (only 4 screws).
I'll post photos of the PID modifications tomorrow or later in the week.
Russell
P.S. I hope this all isn't too much. One reason Im doing it rather than just providing written descriptions is that someone over on Coffee Geek questioned my "veracity" which I interpret as an oblique way of saying I'm lying about my tests and mods. I own three machines, a Silvia, an Eliane, and a Solis SL-90 and I've spent considerable time and money modifying both the Silvia and the Eliane. I want to see if I can get results out of the Silvia which (to my uneducated taste) are comparable to those from the Eliane. Then I can sell the modified Eliane and keep that nice unassuming Silvia with a good conscience. But if I can't get comparable results, the Silvia goes.
