Are those marks or grooves on the piston?
They are not grooves but marks. I went over them with my fingernail and felt no real depressions. It is just slightly scored (more rough than scored) on the finish, but I woudn't call them grooves.
Can someone help me understand the operation of the spring? Does the piston move back during a shot or what? I think the marks are there because the thing is screwed in, almost to the maximum point. If the spring allows the piston to move...well, I don't think it is. That could be what the marks are from. If the piston stays in a static position instead of having some travel.
I just completed a second descale, just in case I missed something on the last try. The water came out so clean you could drink it (if it weren't citric acid water). At the very last purge of the steam wand a small amount of a dark water came out though. Could I be breaking down a washer or something from descaling again so soon?
Anyway, after the 2nd descale the pressure problem still exists. So, I'll get in touch with 1st Line on Monday and try to get the spring.
Barry B
