(emphasis added)Pressure on the cake does not remain constant during the percolation process, but varies as a function of the characteristics of the hydraulic circuit above the cake. This can be verified by continual pressure sensors: the recordings yield a function p = p(t) which exhibits an initial transient rise, increasing more or less slowly. The dry bed still lacks adequate cohesion and is susceptible to resettlement; therefore the initial phase appears to be decisive in percolation. After wetting, ground coffee particles swell up firmly interpenetrating each other, and percolation can follow its stationary course. This effect explains why...the flow is not constant during percolation, rather showing an 'asymptotic flow dependency'. .... Hydrodynamic experiments demonstrate that the average flow ceases to depend linearly on pressure in the proximity of 9 atmospheres and that an increase in pressure actually causes a decrease in the average flow....
timo888 wrote:There's an interesting discussion of pressure in the Illy book (ch. 8 passim). Illy refers to the "time-dependent geometry" of the puck, citing a thesis by G. Baldini, Filtrazione non lineare di un fluido attraverso un mezzo poroso deformabile (Firenze, 1992). Illy writes:(emphasis added)Pressure on the cake does not remain constant during the percolation process, but varies as a function of the characteristics of the hydraulic circuit above the cake. This can be verified by continual pressure sensors: the recordings yield a function p = p(t) which exhibits an initial transient rise, increasing more or less slowly. The dry bed still lacks adequate cohesion and is susceptible to resettlement; therefore the initial phase appears to be decisive in percolation. After wetting, ground coffee particles swell up firmly interpenetrating each other, and percolation can follow its stationary course. This effect explains why...the flow is not constant during percolation, rather showing an 'asymptotic flow dependency'. .... Hydrodynamic experiments demonstrate that the average flow ceases to depend linearly on pressure in the proximity of 9 atmospheres and that an increase in pressure actually causes a decrease in the average flow....
Regards
Timo
timo888 wrote:A very good experiment and observation. We await the photo-essay
There's an optimal pre-infusion volume and pressure and time. Too little or too much of any of them and you get a cake with a dry bottom, or a cake with channels, or a cake so tightly swollen it's hard to get the brew water through it.
But if I'm going to err, I prefer to err with too long a preinfusion, especially if my water is on the cool side and I've not overdosed the basket, so there's room for the cake to expand.
Regards
Timo
LeoZ wrote:does this apply to preinfusing? i can see what cannonfodder is saying - that makes sense. but if the puck is preinfused, and a linear ramping of pressure is applied (how most e61s act), i dont see flow becoming an issue, only bitterness!
another_jim wrote:Love the garden faucet handle; combined with the PID panel it's either surreal or post-modern
erics wrote:I.E. keep the bean type constant, keep the dose constant (weight), keep the tamp constant, keep the brew water temp constant (as best you can) and keep the shot volume/time constant.
Eric S.
cannonfodder wrote:And there in lies the conundrum. Not many home baristas are consistent enough in their technique to eliminate all of these variables. After a few years of practice, I am still not there. The problem is that the average home user pulls 3 or 4 doubles a day. A professional Barista pulls several hundred in a day. If I had a local cafe worth bothering with, I would even work for free every now and then just for the practical experience.
timo888 wrote:I read somewhere that the next Versalab system (the M4Xh) will have an integrated hygrometer and provide grind-adjustment recommendations.
Regards
Timo
LeoZ wrote:... if the puck is preinfused, and a linear ramping of pressure is applied (how most e61s act), i dont see flow becoming an issue, only bitterness!
