Preinfusion on the E61 - revisited
Link to "Preinfusion on the E61 - revisited"by bigdog002 on Tue Dec 18, 2007 12:21 pm
I read all I could on preinfusion, the concensus seemed to be that a non-plumbed machine can't do it properly. Those with an Anita or AP seemed to dismiss the amount of water released when the lever is in mid-position as negligable amounts of condensation.
I decided to measure the amount of water released on my Anita when the lever is moved to mid-position. Here are the results....
After machine was idle for several hours -- 1.75 ounces in 10 seconds -- flow stopped. I pulled a double and tested again ... 1.75 ounces in 10 seconds. I immediately turned on the pump until water flowed from the grouphead, shut off pump and moved to mid-position --- 1.75 ounces in 10 seconds. I tested several more times throughout the day, each with the same result .. 1.75 ounces in 10 seconds.
1.75 ounces seems like plenty of water for an effective pre-infusion to me ... ? ... It can't be all condensation because the same amount of water is delivered immediately after pulling a shot and/or after running water through the grouphead.
Again I ask, why is this feature not used and dismissed on these Quick Mill machines? It seems to me it is part of the design. I pulled my first double this morning with a 6 second pre-infusion (approx 1oz) ... the shot was the best I had ever pulled, no squirters at all. I'm going to continue to use MANUAL pre-infusion with my Anita and see if the results are consistent.
Is the preinfusion water correcting distribution problems by saturating?
I'll post more as I experiment.
Chris
EDIT - I'm leary of the theory that the vibe pump slow ramp up is 'the' preinfusion on the E61. That may very well be a characteristic of the vibe pump, but I do not believe it is the designed preinfusion on the E61. I contend that those with a full E61 are not getting the preinfusion promised automatically ... that it might be designed as a manual operation with the lever. Again, just my thoughts, prove me wrong if you wish, I'm just trying to fully understand and get the most out of my (lovely) Anita.
bigdog002
Link to "Preinfusion on the E61 - revisited"by jesawdy on Tue Dec 18, 2007 1:24 pm
bigdog002 wrote:I read all I could on preinfusion, the concensus seemed to be that a non-plumbed machine can't do it properly. Those with an Anita or AP seemed to dismiss the amount of water released when the lever is in mid-position as negligable amounts of condensation.
I'm short on time to give a full response, but I think you may be confused on how the preinfusion on a machine like the Anita works. Some might argue that preinfusion (as it was intended by the E61 patent) only works on Levetta (brew lever-equipped) machines, like you have with the Anita. Have you read and understood the E61 patent info in E61 Group Espresso Machine: Is its reputation justified??
Jeff Sawdy
jesawdy
Link to "Preinfusion on the E61 - revisited"by cafeIKE on Tue Dec 18, 2007 1:26 pm
Perhaps the topic should be Preinfusion on the Anita?
The Quickmill group design differs from that of the Vibiemme where the middle position releases no water. FWIW, Vibiemme traces its ancestry directly to Faema, the original manufacturer of the e61.
What happens if you run enough water through the group to drop the temperature well below boiling? Do you still get 1.75oz in 10 seconds? If not, then the 1.75oz may represent the water in the thermosyphon expellable by the super heated water. Once 1.75oz is released, is just a small amount of steam released?
cafeIKE
Link to "Preinfusion on the E61 - revisited"by bigdog002 on Tue Dec 18, 2007 1:50 pm
cafeIKE wrote:Perhaps the topic should be Preinfusion on the Anita?
I repeated this cycle 4 times -- 8 oz flush, mid-lever. All 4 gave the same amount of water. When the flow stops the brew pressure is dead 0 and I detect no steam (doesn't mean there is none, not great eyes here). There was a difference in how the water flowed. The cooler water flowed out in well defined streams, compared to a more spread, single drop pattern with hot.
I do agree that it is likely some form of 'trapped' water, as the amount is consistent. See my response below for more ...
bigdog002
Link to "Preinfusion on the E61 - revisited"by bigdog002 on Tue Dec 18, 2007 1:56 pm
jesawdy wrote:I'm short on time to give a full response, but I think you may be confused on how the preinfusion on a machine like the Anita works. Some might argue that preinfusion (as it was intended by the E61 patent) only works on Levetta (brew lever-equipped) machines, like you have with the Anita. Have you read and understood the E61 patent info in E61 Group Espresso Machine: Is its reputation justified??
I read it and tried to weed out the preinfusion info. The claim of any meaningfull preinfusion designed into the E61 seems dubious to me, more of a marketing gimic.
It seems I am addressing a bonus feature of Quick Mill machines, rather than an E61 design feature. This is actually quite exciting for Quick Mill owners ... If a Quick Mill owner has the option to saturate the puck with up to 1.5 ounces of non-pressurized water before pulling a shot, this adds a REAL preinfusion that was previously only available on a lever machine ... am I correct in that thought?
What other HX machines are able to deliver water in mid-position?
EDIT: Just pulled my 2nd double with a 6 second mid-lever puck soak ... 17g of Black Cat, WDT'd ... shot pulled in 20 seconds (26 seconds with preinfusion time), when it started to barber-pole I cut it off. 1.5 ounces, crema to the 2oz mark, and the most beautiful crema I have ever produced.
EDIT2: pulled my 3rd double. I updosed to 18g, 6 sec soak, 24 sec pull and it was a thing of beauty. My inexperienced eye could detect no fault in this one. I stopped the pull only because my timer went off. Wish I had a video camera.
I drink cappas, I can detect bitter/sour in a second .. the last two cappas were the best I have ever tasted, and certainly the best I have ever made myself.
Maybe concentrating on this 'soak' time has taken my mind off of the dose/tamp routine so I'm more relaxed and doing those things properly ... or maybe soaking really makes a difference.
I'd certainly like to hear from some other QM owners.
bigdog002
Link to "Preinfusion on the E61 - revisited"by jesawdy on Tue Dec 18, 2007 4:49 pm
Not to take away from your experimenting (which I think is interesting), here's the bit on preinfusion that I wonder if you are not grasping:
From the patent (linked from here)
In practice, during some moments, there is no pressure. Then, the pressure begins to be formed. When the pressure in the chamber 14 reaches (in the case in question) 1.5 atmospheres, this pressure overcomes the power of spring 8 and the sealing device 7 becomes detached from the seat. But in the supposition in question, the sealing device 10 remains in the off position. As the hot water still arrives in 14, this water, little by little, fills the cavity 9. After this filling, the pressure in 14 and above the coffee powder contain in the filter, rapidly increases under the action of the pressure in 3, and then the infusion is distributed. After this distribution, by operating the handle 14 in the opposite manner, the starting conditions are reestablished.
It is evident that, by regulating the opening 2, the spring 8, and the volume of chamber 9, it is possible to obtain the desired period of the phase of infusion with the desired pressure of infusion.
So chamber 9 and spring 8 are the really important bits (and only on a levetta machine). Brew water fills chamber 14 and travels up 4 and starts wetting the coffee in the portafilter. Sufficient pressure builds to overcome spring 8 (patent claim of 1.5 bars, this could be varied with different springs) and now the preinfusion chamber 9 starts to fill. Once 9 is full, the pressure builds to brew pressure and the espresso is extracted.
Jeff Sawdy
jesawdy
Link to "Preinfusion on the E61 - revisited"by bigdog002 on Tue Dec 18, 2007 6:03 pm
jesawdy wrote:Not to take away from your experimenting (which I think is interesting), here's the bit on preinfusion that I wonder if you are not grasping:
*snip*
The E61 preinfusion described above happens when the lever is moved from bottom to top, correct?
If yes, does the amount of preinfused water have time to actually affect the puck? It seems to me the time it takes the pressure to build to overcome spring 8 wouldn't be very long. If this is indeed the way E61 preinfusion is designed it seems too little and too short of time to have any actual effect on the puck. Am I underestimating the amount of water and time allowed built in to the E61?
Or are you saying that the water held in the cavity (9) is the water that is being released when the lever is mid-position and the user IS supposed to manually control the time of preinfusion?
After realizing that mid-lever soak is NOT actually part of the E61 design, I am now focusing on the water released when the levetta is mid-position .. plenty to fully saturate a puck and give it time to actually be absorbed before pressure is applied. This seems to be a characteristic, not a feature, of some E61 designs.
If I am understanding the built in E61 preinfusion process, and it happens when the lever is moved from bottom to top ... thats about 1 second of preinfusion ... ? .... depending upon the amount of water I guess it could help a bit. The mid-lever time controlled preinfusion I've discovered on my Anita seems unintentional, but it seems to give the user very good control over a lever-machine type of preinfusion, which seems to be very effective from what I've read.
If I am making no sense keep trying to get through to me, I will eventually see the light ... I'm just new at all of this 8)
bigdog002
Link to "Preinfusion on the E61 - revisited"by jesawdy on Tue Dec 18, 2007 6:26 pm
bigdog002 wrote:The E61 preinfusion described above happens when the lever is moved from bottom to top, correct?
Yes.
I suspect it is not too very long at all as well. I don't directly know if it is sufficient time to fully wet the whole puck as I've personally never played with it. Surely it is bit different than it is with a lever machine (as you mentioned) where you can preinfuse as long as you wish. The patent acknowledges this about lever machines.
No. Before pulling a shot, chamber 9 is emptied to the drip tray. No you are not supposed to control preinfusion as it is designed. You could with a plumbed machine and mains pressure and use the mid position. On the QuickMill variants at least. Or play as you are. Or install some sort of delay timer.
If I am understanding the built in E61 preinfusion process, and it does happen when the lever is moved from bottom to top ... come on, thats about 1 second of preinfusion ... ? ....
This isn't much different than what Gicar controllers that support electronic preinfusion do. On so equipped La Marzocco and other machines, electronic preinfusion pulses the pump on/off very quickly, pauses a short period of time and then the pump is back on to pull the shot (not sure on the exact timing of this pause, 2 seconds maybe? Not adjustable as far as I know).
Jeff Sawdy
jesawdy
Link to "Preinfusion on the E61 - revisited"by bigdog002 on Tue Dec 18, 2007 6:37 pm
Thanks Jeff. Interesting stuff.
I'm very excited to discover I can control preinfusion time on my Anita in a way that is similiar to the control of a lever machine. So far my results when using a mid-lever soak have been great.
I'm anxious to see the results of others who have not tried this technique before (and from those that have). It probably benefits newbies like myself more than experienced users, maybe it will help people with my experience level to get better and more repeatable results.
bigdog002
Link to "Preinfusion on the E61 - revisited"by HB on Wed Dec 19, 2007 12:56 am
bigdog002 wrote:I'm anxious to see the results of others who have not tried this technique before (and from those that have). It probably benefits newbies like myself more than experienced users, maybe it will help people with my experience level to get better and more repeatable results.
I call what you describe "prewetting the coffee" since there's no pressure involved and agree that it can boost the margin of error. My brief informal tests with it awhile back suggested that it improved the likelihood of an even extraction, but also "muddied" the flavors. For some coffees it was no big deal (e.g., monotonic comfort blends dominated by chocolates), others with lots of light fruity notes suffered greatly.
As a point of reference, you may be interested in the thread Pressure profiles, preinfusion and the forgiveness factor. It was my first "ah ha!" experience with an espresso machine that was both devoid of preinfusion and yet delightfully forgiving of minor errors in barista technique:
Which brew pressure profile is more barista friendly?
PS: For keeping my own terminology straight, I refer to vibe pump machines with gicleurs as having progressive preinfusion, i.e., a slow pressure rise with no mechanism to produce a distinct brew pressure "hump". I refer to the E61s with expansion chamber and levers simply as having preinfusion because their brew profile is clearly separated into phases. Not sure if these terms jive with the various patent disclosures, but they've worked for me.
Link to "Preinfusion on the E61 - revisited"by erics on Wed Dec 19, 2007 10:52 am
Big Dog -
Excerpted from Section 4.3 of this post:
http://www.home-barista.com/forum...perature-t516.html
Water absorption by the coffee cake: A series of measurements were performed, in which a dry portafilter was dosed with coffee and weighed. The portafilter was reweighed after espresso was brewed from the coffee. The measurements show that a dry coffee cake absorbs approximately its own weight in water during the brewing process, about 18ml for a double espresso shot.
Just for the heck of it, I measured the weight of the originally dry 15 gram "used" puck this AM and it tracked very closely with the above - 15.5 ml. That's about 0.5 ounces of water.
In this post:
http://www.home-barista.com/forum...1-t5472.html#64086
There were conflicting (harmless) reports of exactly what happens when the brew lever is moved to the mid position - a very pronounced detent. A short perusal of lots of posts on the subject would show, I believe, that the brew valve is nudged slightly open when the lever is in this position HOWEVER I would tend to agree with Ian when he responded that all valves are closed when the lever is in the mid position - it seems natural. In any event, whether the valve is nudged open or remains shut could rather easily be changed by the end-user by swapping a few parts or adding/removing a shim in the right place. I, for one, don't make any use of this mid-position (although my Anita is one of the nudgers) as the inherent pre-infusion of the group seems to work OK.
But back to your 1.75 ounces - that's a lot of water and, exactly how much of it is used to saturate or partially saturate your puck can be seen/measured simply by removing your portafilter after "X" seconds of having the lever in the mid-position and "catching" the water that escapes. Keep in mind, of course, that when you start the pump, that 1.75 ounces has to be made up before any flow through the puck takes place. In addition, that 1.75 ounces was a VERY RUDE :) interruption to the thermosyphon flow that was happily moving along.
Skol and,
Skol,
Eric S.
erics
Link to "Preinfusion on the E61 - revisited"by erics on Wed Dec 19, 2007 11:27 am
Even LM thought it was a good idea at one time:
http://www.google.com/patents?id=...ec=abstract&zoom=4
Skol,
Eric S.
erics
Link to "Preinfusion on the E61 - revisited"by Alex G on Wed Dec 19, 2007 5:10 pm
I too am curious about the importance of preinfusion. I realize that most of the discussion on this thread has related specifically to the Anita so perhaps my question isn't perfectly related, but... I have a plumbed-in Izzo Alex. When I put my lever in the mid position, I get steady watermain pressure at about 2.5 bar for as long as I leave it in this position, and the rotary pump does not turn on. So I'm assuming that doing this for a few seconds is what is normally referred to as preinfusion. I can soak the puck at a very low pressure before fully engaging the lever and starting the pump. My question is - should I bother? I've done some limited testing with and without preinfusion, and came up with ambiguous results. My feeling is that technique in the grind/tamp/dose was more important to achieving shot consistency, but frankly, I haven't yet taken enough time to really examine the difference between preinfused and non-preinfused shots. I'd be glad to hear from anyone who has a pre-infuse capable plumbed-in machine. Does preinfusion matter? Will it effect quality in the cup?
Thanks.
Alex.
Alex G
Link to "Preinfusion on the E61 - revisited"by jesawdy on Thu Dec 20, 2007 11:29 am
Alex G wrote:I too am curious about the importance of preinfusion. I realize that most of the discussion on this thread has related specifically to the Anita so perhaps my question isn't perfectly related, but... I have a plumbed-in Izzo Alex. When I put my lever in the mid position, I get steady watermain pressure at about 2.5 bar for as long as I leave it in this position, and the rotary pump does not turn on. So I'm assuming that doing this for a few seconds is what is normally referred to as preinfusion. I can soak the puck at a very low pressure before fully engaging the lever and starting the pump. My question is - should I bother? I've done some limited testing with and without preinfusion, and came up with ambiguous results.
A recent post on a Barismo discusses this (see http://www.barismo.com/labels/delay%20timer.html) on an older LM (I think). They seemed to be happy with the results. Ken Fox has also added a delay timer to add preinfusion to his Cimbali Junior(s?), see here and here.
With your plumbed Alex, no need to have the timer. You do need to control the inlet water pressure with a pressure regulator (and maybe an accumulator would be a nice addition). If the lever mid position on the Alex wets the puck, you can play until your hearts content. My gut feeling is that this will not have drastically different results on an E61 machine in comparison to a LM with no gicleurs, La Cimbali or other machines with no preinfusion.
Jeff Sawdy
jesawdy
Link to "Preinfusion on the E61 - revisited"by RegulatorJohnson on Sun Dec 23, 2007 5:57 pm
this is a fun thread.
i messed with this a bit. my wife is usually my "blind" guinea pig. if i know im doing something different its going to skew my results. so i experiment on my self then do the same fer her without telling her that anything is different. so she gets a full blind opinion i just ask her how it is, she doesn't know if its a different bean or pre-infused or what...
so we are in probably our 7th pound in a row of bigfoot espresso we love it. so its the same each day as far as technique goes then i try this preinfusion 10 seconds @ line pressure of 3.745ish bar, then lift he lever to full brew. it seemed to produce a different cup for sure but its like its smoother or more blended or texturally different. anyway i make one for her with the preinfusion and don't say anything. she takes a sip... "WOW! this is REALLY GOOD are these different beans?" nope.. :D she said it tasted fruitier and more sweet. so this is just what happened for me.
i like it. i am thinking of changing the shape of the cam on the lever so it will be easier to put in the correct position without activating the pump accidentally.
thanks for the time.
jon
jon stovall
thebeaningoflife.com
expobarownersgroup.com
RegulatorJohnson
Link to "Preinfusion on the E61 - revisited"by Bluer Ridge on Mon Dec 24, 2007 6:49 pm
Have become addicted to reading these exchanges since my 13 year old Black & Decker pump died 3 months ago. I have since learned how hard it is to know what you don't know, especially about the prosumer E61 Hx technology.
I will plunge ahead with some likely naive questions to further unveil my ignorance, and perhaps one day (soon) I will have the wisdom to own an espresso machine again. I have relied heavily on some of the schematics and cartoons on this site and perhaps that is my problem.
Concerning the idea of preinfusion and how it happens -
My understanding is that preinfusion means subjecting the puck to (some) water prior to the fully pressurized bolus which makes the shot. When the handle on the manual E61 is down, the pressure in the cam pocket and preinfusion chamber is room pressure. In the middle (horizontal) position, the preinfusion chamber is closed by the 1.5 bar spring, the upper chamber (upper sleeve assembly) is now open to the cam pocket area and therefore the puck. Pressure builds in the cam pocket (& above the puck) until it reaches the thermosyphon pressure, which I take to be greater than 1.5 bar (the spring tension needed to open preinfusion chamber spring). There is some debate about how much communication between cam chamber and upper chamber there is at horizontal position, but my sense is that the critical difference is pump pressure, which is only activated when handle is up (is this right? As you must know by now, I have never been in personal contact with an E61). So the preinfusion is exposing the puck to the thermosyphon pressure before any pump pressure. (What is the thermosyphon pressure, I should ask.) It is unclear to me precisely what function the preinfusion chamber has, as the puck is already exposed to the thermosyphon pressure. The preinfusion chamber fills once the preinfusion spring pressure is overcome (about 1.5 bar) by the increasing pressure in the cam chamber. Once it fills and is isobaric to the cam chamber, the spring will close again. I am not sure what its function is.
I am also confused by the E61 drain valve - the drain valve spring as mentioned in the patent, is around 7 atmospheres. So why doesn't the pump water (greater than 7 atmospheres?) go out the drain valve instead of through the puck? What pressure is needed to push a shots-worth of hot water through the puck in 25 seconds? (Less than 7 atmospheres?)
There was discussion about the differences of preinfusion between reservoir and plumbed units. I don't see the difference, if the preinfusion is a result of the exposure of the puck to the thermosyphon pressure (at least for the E61 Hx) and not the main pressure (which is "behind" the pump, and which is off during preinfusion...)
Well, no doubt my points will be met with frustrated head shaking among the engineering and PhD types who vigilantly parole this site, but I'll be stronger for it. Thanks for your help and forbearance.
Bluer Ridge
Link to "Preinfusion on the E61 - revisited"by HB on Mon Dec 24, 2007 9:49 pm
Bluer Ridge wrote:Well, no doubt my points will be met with frustrated head shaking among the engineering and PhD types who vigilantly parole this site, but I'll be stronger for it. Thanks for your help and forbearance.
Eric's diagram shows us the "big picture":
erics wrote:
From Can anyone explain preinfusion on the E61?
The image of the E-61 group is copyright 2005 by Verna Design, Inc. It is shown in the brew position.
My attempt to explain the rest of the story is excerpted below from Is there a purpose for the E61 middle brew lever position? My terminology is slightly different than yours. I refer to the chamber containing the orange cam as the brew chamber and the chamber beneath it as the expansion chamber.
HB wrote:Please do not copy these images.
The first image shows the E61 lever at the rest position. The two lower valves are open to allow the brew chamber and expansion chamber to drain. The uppermost valve is closed. Water from the HX circulates through the upper port on the left, passes alongside the "mushroom" to heat the grouphead; as the water cools it descends through the lower port on the left. The temperature difference creates a thermosyphon that circulates water between the boiler and grouphead.
The next image shows the E61 lever at the mid position. The two lower valves are closed and the upper valve is barely open. If this pump has line pressure, water will flow through the upper port, grouphead cap and screen, gicleur (yellow), descend towards the brew chamber (orange cam), and finally through the L-shaped channel to the brewhead. It's easy to see the purpose of the Allen screw (gray); it caps the hole drilled during manufacturing for the first leg of the channel.
EDIT: Ian correctly notes the Vibiemme Domobar Super does not allow flow at the mid detent; a number of E61 clones do (e.g., Quickmill, Isomac, and Expobar).
The final image shows the E61 lever in the brew position. The upper valve is held open by the orange cam. The valve at the bottom of the expansion chamber is held tightly closed by a spring. The spring above it holding the second valve closed is weaker; it will open at about 4 bars of pressure. It only takes a second or two for the brew chamber containing the orange cam to pressurize. As the pressure builds, water eeks pass the valve below the orange cam, allowing the pressure to drop. This action is the novelty claim of the E61 patent since the pressure is automatically lower as the expansion chamber fills. Once the lower chamber fills, the pressure equalizes in all chambers and the valve below the cam closes.
The familiar "whoosh" that follows the lever being lowered is water evacuating the brew chamber and expansion chamber. Again at rest, the expansion chamber and brew chamber are empty. Water continues to circulate along the jacket of the uppermost chamber as the thermosyphon re-establishes itself.
Link to "Preinfusion on the E61 - revisited"by Gregg K on Mon Dec 24, 2007 10:17 pm
Thank you Dan!
I think I've got an understanding of how it works. And I find it very exciting. I don't know what took me so long to get into espresso. But as a mechanical engineer, a coffee lover, and someone who has a genetic predisposition for thermodynamics, this stuff is a lot of fun.
The power of the forum is great. Carry on...
Gregg K
Link to "Preinfusion on the E61 - revisited"by Bluer Ridge on Mon Dec 24, 2007 10:58 pm
Yes, Dan, your diagrams are helpful. Especially the expanded diagram of the entire machine and not just the E61 (still don't know where the steam frother comes in). I am still confused, but perhaps I just need to study and follow along longer. I assume the cam never closes off or restricts the L channel aperture in any position - is this true?
Still confused about the role of the middle position in those machines for which the upper valve is at least partially opened. As I noted, the puck is subjected to the pressure of the heat exchanger tubing (I assume it is pressurized because it is closed and hot) and therefore must be experiencing some so-called preinfusion, without the lever up (and pump on). Unless it is understood that the (low?) pressure merely from the heat exchanger tubing and the hygroscopic property of the coffee rounds is insufficient to wet the entire puck. What am I missing here? A brain?
Bluer Ridge
Link to "Preinfusion on the E61 - revisited"by erics on Tue Dec 25, 2007 1:28 am
The purpose of the operating cam inside the group is strictly mechanical. I can see where you might think it could close off the brew port but, no, that does not occur in any position.
The middle position is a prominent detent on E-61 lever machines and, as such, one would think that the brew valve is not being moved. Certainly, on Ian's machine (and probably on a host of others), it does not; on my machine (and probably on a host of others), it does. Pressure builds up in the heat exchanger when the lever is in the full down position due to the expansion of the water within that circuit. This pressure is typically limited to the setting of the OPV (over-pressure valve) and instantaneously falls to zero or thereabouts when the brew valve is nudged open even the slightest amount.
For most users, this is not relevant because the middle position of the brew lever is simply a "bump in the road" that one must pass through in brewing the espresso. For users that have a plumbed-in machine whose brew path is always subjected to line pressure (and whose brew valve is nudged open when the lever is in the mid-position), this can be used to pre-preinfuse the espresso. I say pre-preinfuse because the E-61 lever machine has an inherent preinfusion stage as part of the brewing process - see Dan's explanation.
The extent to which this preinfusion (really of any type) is advantageous can be debated ad infinitum. Personally, I believe it to be beneficial as regards a more consistent brew but there certainly exists espresso machines which either don't employ it or it is not utilized AND that still produce outstanding results. The espresso grounds can certainly be wetted by the hot water which manages to pass through a nudged open brew valve (non-plumbed-in machine) but the pressure is basically zilch - maybe 2 to 3 inches of water height. Will the entire puck be saturated? - I do not think so unless one wants to take a short nap and this would sorta be counter-productive. :cry:
Doing a site search with the key word being "preinfusion" could keep you quite busy for a few days.
Skol,
Eric S.
erics
Next
Return to Espresso Machines
