by Dr Jim on Sat May 27, 2006 4:17 am
Since I may have inadvertently caused some confusion by posting the 'Fellini Move' topic, perhaps I should try to clear things up a bit...
My original posts were all directed towards spring-lever machines like the Elektra, the Ponte Veccio, big Gaggias, and my Conti. Please remember that these machines all work by the operator lowering the lever down, which raises the piston, compresses a spring, and uncovers ports through which hot water at boiler pressure (typically 1.2 - 1.5 Bar, or 18-24 PSI) can then flow and pre-infuse the puck.
Commercial spring-lever machines often have a pre-infusion detent which holds the lever down at the bottom of its stroke until the operator manually lifts the lever up to begin the shot. Traditionally, the lever was left lowered until the first few drops of liquid appeared at the portafilter spouts - these drops were allowed to fall into the drip tray, then the lever was gently raised with one hand while the other positioned the cup(s) under the spout.
The 'Fellini Move' simply adds a 3-5 second post-infusion phase where the lever is brought off the pre-infusion detent, pressure is briefly applied to the puck, the lever is returned to the pre-infusion detent for several seconds, and then gently lifted off the detent and the shot pulled normally.
Direct-action lever machines like the Pavoni, the Olympia, and the Gaggia Achille all work in an opposite fashion, in that the operator raises the lever to expose ports which allow water under boiler pressure to flow onto the puck - the Achille may operate at reduced pressure since it claims to use an HX loop fed by its own water reservoir - but in all cases, low-pressure hot water fills the chamber and floods across the top of the puck.
If the direct-lever operator wanted to achieve a pressure profile similar to a spring-lever machine's, I imagine that raising the lever, holding up at the top of its stroke for 3-5 seconds to ensure that the puck was flooded, the chamber full, and any steam bubbles purged would be the first step. Then I would further imagine that one would gently lower the lever until resistance was felt, continuing until you reached roughly 3-4 pounds of downforce on the lever, at which point you would attempt to hold this pressure until the first drops appeared or about 20 seconds, before applying the full 30-40 pounds of downforce needed to complete a shot.
I'm not sure that there's any advantage to be gained by attempting to duplicate the 'Fellini Move' on a direct-action lever, but if you are determined, I would guess that the closest approximation would be to press down with full force for 1-2 seconds, release back to 3-4 pounds on the lever for 3-5 seconds, then resume the full-force extraction. I don't see anything good happening by raising the lever at this point, and do see a potential for a number of Bad Things like fracturing the puck or introducing steam bubbles if the lever is raised.
Open-boiler machines like the Peppina or the Mini-Gaggia operate at atmospheric pressure and hence do not have a pre-infusion phase unless the operator chooses to invoke one by manipulating the lever - in which case the techniques will vary not only between manufacturers, but often from machine to machine depending upon age and condition.
However, the point which I started out to make - a very long time ago, sorry - is that I don't believe that pre-infusion tactics have anything to do with soupy, wet pucks - which I always attribute to defects in my tamp/grind/distribution techniques, which I immediately attempt to analyze and adjust. A process which I find fairly frustrating, and my neighbors - who get to watch a middle aged man in bathrobe and slippers swear blue oaths over some coffee grounds - find somewhat 'disturbing.'
Cheers
Jim
LMWDP #26
