by DickC on Thu Jul 05, 2007 7:59 am
I'm fairly happy with my Expobar lever, but it looms a bit large on my counter. With reservoir gone (plumbed in) and soon pump too, there's not really that much left. Grouphead & boiler with attachments, valve-wands, gauge, heater-light, switch, -- front panel has just 9 holes -- fill-controller, that's about it. Just a lot of empty space inside some sheet metal.
I'm thinking of something cylindrical (octagonal?) that would mount from the side to a wooden column I happen to have coming up through the counter, supporting the ceiling. The machine would then use near-zero counter space.
Although I could presumably buy all the parts to build a machine, they would cost more than the Expobar did, and for sure a lot more than I could get for the Expobar. Also, presumably, all these parts now work together and would still do so with different structure and covers...
So what obvious problems am I not seeing with this scheme?
It *seems* like just sheetmetal, machining, plumbing, and a little wiring.
Of course, I do know that this little project will obey the First Law of Projects: "It takes longer than..." (Than you thought, than you planned, than it should, etc.) But otherwise?
Are there subtle issues of machine tuning for thermal issues, having to do with shape, volume, airflow that affect coffee brewing and so on?
I might want to reposition the boiler more directly behind the grouphead, which might shorten the lower thermosyphon tube some and raise the boiler relative to the grouphead -- problems?
Comments, criticism, constructive ridicule -- all much appreciated.
-Dick
