by Ken Fox on Sat Jul 29, 2006 11:29 pm
Regarding the initial question, PID vs. the Barksdale pstat, I have no opinion for any particular machine being as I don't have any idea how likely one is to reach better temperature stability with a boiler PID in HX machines other than those I own, with a PID vs. this pstat. I also have no experience with this pstat itself. Eons ago, before I PID'd my vibe machine (the rotary has been PID'd for more than 2 years), I discussed the then novel CEME (supposed) low deadband pstat with Michael Teahan, my usual referral expert on such matters, and he mentioned the Barksdale as an alternative, mentioning Gimme as the place to call. I never bothered, but for no good reason. Without doubt, a truly functional low deadband pstat is going to be a much easier and less time intensive installation than is a PID.
When the CEME proved to be worse than useless on the old vibe machine, I went directly to a PID, and the implementation on my old vibe machine has been, if one bases success on results obtained, better than on my newer rotary machine. I am able to preserve the HX hump and to get somewhat better intershot temperature stability on my 10+ year old vibe machine than I can get on my current vintage rotary Cimbali Junior which doesn't seem to have much interest in humped profiles whatever I do with it. But I digress.
There are several issues here that are all getting mixed up and the "right" decision about what to install for one person may be the wrong decision for another. I would not recommend mounting a PID inside of a machine exposed to the expectedly hot temperatures one would encounter near a boiler. Barry Jarrett has pointed out that there is an "internal reference junction" inside of PIDs, or at least inside of the Fuji PXR3, and if this is not ventilated to outside air the behavior of the PID controller can be erratic. I would defer explanations of this to Barry, however he convinced me that I could not expect stable performance with a controller that was not ventilated, who tried such installations and found them wanting. What this means is that you need to install the controller external to the machine. In order to do this well you need a project box, and there are a plethora of options out there of aluminum project boxes that are only a little bit larger than the size of the Fuji and similarly sized controllers. Mouser.com is a good source for stuff like this. There are also plastic box options if you don't mind looking at them.
The SSR can likely be mounted using the machine's chassis as a heatsink, which is what I've done in both of my installations. I have placed a TC next to the endplate of these SSRs, as recommended by an SSR mfr's tech support, and temperatures measured showed that the machine chassis worked well as a heatsink.
So, the installation can be done in a way that is not too ugly but one has to locate the project box in a place that with a water accident (e.g. such as a drip tray overfilling, and these things do happen and have happened to me) the controller will not be exposed to water, also the controller itself should be fused, which is easy enough and might add a dollar to the overall project cost. But only you can determine if having a project box outside of your machine will mar its appearance to a point where you can't live with it. I do not find either of my installations to be visually offensive but that is a personal call.
The PID, as Jim has pointed out already in this thread is apt to be very reliable if you don't have an early electronic component failure. The Mater and the CEME are both glorified pieces of sh*t, if one is talking of reliability, quality, and service life. I know nothing of the Barksdale and can't comment on it.
OK, that is one issue, basically the difficulty and the appearance of the end result, of putting in a PID vs. putting in this particular pstat.
Here's another issue; do you want to control your shot temps? Now, there are ways to control shot temps and these are going to be very machine dependant. I'm sure that Dan Kehn has his Elektra nailed and can get within a degree or two on his stock machine just by water dancing and the like. Even he would say that the first shot he gets is more of a crapshoot. I've demonstrated ad infinitum that with a PID on my machines and with a low temp boiler setting and with a small flush I can reduce the variability of the hard to control first shot. I have to say however that in extended testing (yes, I have "published" only a small fraction of the shot temperature graphs I've accumulated over time and have tried a whole lot of scenarios with varying the flush volumes, boiler temps, interval between flush and shot pulling, etc. etc. etc. but have not "published" the results) there is often an "outlier" shot that does not "behave." By this I mean that I might do a series of 10 "walk up" shots, and 9 of them look great and one of them is for sh*t, off by 2 degrees or so for no apparent reason. I can't explain such behavior as it does not appear to follow any pattern. In my own usage such a shot would have at least a 50-50 chance of going into a milk drink, where it would likely not be noticeable, and maybe the other ones are sink shots, I just don't know.
How any of this compares to what one would get on a Barksdale pstat, or how it would work on your machine I do not know.
OK, how about if you want to control your shot temps? Dan K. has the flushing ritual down and he probably doesn't care about this sort of stuff, but let's say you have decided that your SO Harrar Horse makes its best shots at an extraction temperature below 200F, and you have other blends you like that "prefer" 202F? With a pstat that means either getting your flushing ritual down pat, if you can, or it means adjusting the boiler temp. Do you want to have to take a side panel off your machine and get out your small screwdriver every time you need to adjust the boiler temp because that is how you adjust shot temperatures? I don't think so as that is an enormous PITA. Trust me, you won't do it. So, you will be stuck with flushing as your only way to adjust shot temps and it may well work for you.
Since the regimen that works best for me involves fairly low boiler temps, that might not be the best for frothing, what I tend to do is to leave the boiler set at a temp that is best for straight shots on whatever I'm pulling at the moment, and if I want to make a milk drink I bump the boiler temp up a few degrees which allows a good milk drink and attendant frothing to occur. Then in 4 seconds I reduce the temp back down if I think my next shot will be a straight one. Simple. This works well for me because a PID temperature controller is easy to reset temperatures on.
I've found that what I'm doing is easy for me to work with. I don't know if it will be easy for you. I have had absolutely no regrets about having PID'd my two machines.
YMMV.
As to issues regarding safety, I have not experienced an over temperature failure of my PID's. From what I have learned, however, at least on Cimbali Juniors, if you have a pop valve incident the effects are going to recur repeatedly every 10 or 15 minutes and each time water is going to be released and you may get a mess. After the boiler is empty the thermal safety device on the element will kick in. Older machines have an inline fuse of sorts that will ultimately "melt" and need replacement of the part. Newer machines have a pushbutton reset on the side of the outsides of the undertray electronics box (a red button). A PID if it fails is most likely going to be the result of an SSR that is "stuck on." If this happens you will have to rely on the boiler element safety device referred to earlier in this paragraph. Other failure modes are apt to result in the PID shutting off power to the element leaving the boiler water at a lukewarm temperature.
ken
What, me worry?
Alfred E. Neuman, 1955
