HAL9000 wrote:Before trying anything else I would try reversing whatever you did to change the readout from C to F and then try the offset again in C. I have a controller that requires me to change the temp unit in a number of different places in the configuration for it to work, and wonder if yours does too. If nothing else this will remove that as a potential cause of the problem.
Does your controller have the ability to control two separate processes?
Marshall wrote:The Eurotherm has about 60 parameters that are adjusted through a couple dozen submenus nested in 9 top-level menus, all controlled by 4 buttons on a 4-digit readout. I rate my chances of doing more good than harm as slim-to-none, even with the manual firmly in hand.
HAL9000 wrote:That said, I found your instruction manual and notice that there are two different offset adjustments that can be made - one is to apply the same offset to every reading along the entire range, and the other is to pick two boundaries of a range (e.g., freezing and boiling), and then set them separately so that, presumably, the controller will calculate the appropriate offset for any temperature within that range. Which type of offset were you trying to program?
Best,
Paul
Marshall wrote:I also thought it might have been the ability to set two different low/high offsets, except that my PID is currently configured to only make the "low" temp offset visible. I suppose I should look into what is going on with the "high" offset, but am concerned about what I might screw up by accessing it.
Marshall wrote:Yes.
JB130 wrote:Another possibility is that you somehow got yourself into the 2-point calibration menu and set OFS.L = -22F and OFS.H = 0F, leaving OFS = 0. This combination would lead to your symptoms.
cannonfodder wrote:And this is why I still use a commercial pressurestat.
cafeIKE wrote:clickCLACKclickCLACKclickCLACKclickCLACKclickCLACKclickCLACKclickCLACK
Not much of what we have, do we "need."cannonfodder wrote:Sorry, I just don't see the need for one on a HX box.
Some machines have quiet tiny single contact pressurestats, some have full size triple contact commercial models. The large 2" diaphragm in a commercial model makes a snap with a peak level considerably louder than 50db. When guests at a dinner party in the next room ask "What's that clicking?", it's too loud.HB wrote:I've never given it much notice over the "normal" household buzz. Maybe in another 20 years I'll have the luxury of worrying about sounds less than 50 dB.
