That kettle bottom and heater looks a way lot better than most!
My take on lever actions YMMV:
1. Lever down, piston chamber full. water may get to the brew group to
pre-dampen ( depends on group washer and how tight it is. and the amount of air your tamp may allow thru.) Some folks hold the lever down for 10 sec.s at this time.
2. Lever up ,guided slowly by hand,=
pressurized pre-infuse ( kettle/ piston washer closes and group washer opens allowing pressurized water into the puck, usually till first drips.)
3. Lever down and held there then allowed up=
brew. Piston chamber fills then kettle/ piston washer closes and group washer opens to send pressurized water to the brew group.) Some folks do a 10 sec. hold down at this time.
4. Lever down again and released before it has returned to the top = more brew volume.
How far the lever is allowed to rise before the second pull determines total shot volume.
( This ignores a lot of "wondrous Peppina wierdities" that can't be noticed, explained or even described, that go with the experiences of having pulled a lot of shots.)
If the water in your kettle gets a bit brown, you may need a new washers at some time in the future.
Best of joy with your new baby! They are awesome!
Enjoy
richard
