Some time ago, there was a thread in which someone asked about holes in the top of the puck. I'd occasionally seen that, so the next time I cleaned my machine I checked. My Techno is like many other machines in that there is a brass dispersion block with six holes in it. Above that is a small plenum with one hole feeding it. Below the block is the screen assembly, which consists of a stainless disk with holes punched in it attached to the stainless screen itself.
By putting the block over a flashlight, it's possible to orient the screen assembly so that none of the holes in the screen assembly align with the ones in the dispersion block. It's also possible, with a little care, to put the block and screen back so that the feed hole in the head itself lies between two of the six holes in the dispersion block.
Doing this takes less time to do than it does to read about, and pretty much eliminates having the water drill holes in the top of the puck.
David "is this the OCD support group?" Lewis
