www.cafemakers.com: good coffee brings good business
Pavoni Frothing and pressure regulation - Page 2
A haven dedicated to lever espresso machine aficionados.
Link to "Pavoni Frothing and pressure regulation"by Madroaster on Fri Apr 28, 2006 9:43 am
ant wrote:I would prefer not to do the toothpick trick.
-if the wood bit dislodges, gets into your drink, and then gets stuck in your throat? Or worse, someone else's throat? Isn't there a possibility of litigation?
Sorry to spoil everyone's fun, but these are my honest concerns. :|
I'll chime in here with my defense of the toothpick plug... Having removed a plug once to change which hole I had plugged, I can tell you that, at least in my case, dislodging is a pretty unlikely thing. Mine took about 5 minutes to get out, and it came out in pieces. It was in there solid. Perhaps making sure it's in really well can reduce the possibility of it coming out when you don't want it to.
Madroaster
Link to "Pavoni Frothing and pressure regulation"by escabi on Sun Jun 03, 2007 2:09 am
Here is a quick fix replacement tip for the Pavoni three hole steam tip. I purchased some stainless acorn nuts from my local hardaware store and drilled a hole with my drill press. I have another with two forward facing holes. Microfoam has never been easier.
escabi
Previous
