odradek wrote:The machine is actually brand new - just bought from Italy. Perhaps if I posted a picture of the problem it would be better?
Hi odradek,
My first post here, actually, but i've been lurking
I'm a bit confused--a machine shouldn't get actual "condensation" on the base of the boiler--that would occur if the air was warmer and more humid on the exterior of the boiler while cold on the inside of the boiler. As we all know, the boiler gets ridiculously hot even early in the warm-up.
Also, does the water that you notice rapidly boil away as the boiler heats up to brew temp? That is--is it a temporary problem during the heat cycle?
Two thoughts as to the water's origin:
1. On my pavoni (millenium europiccola small boiler size), during the heating up cycle I frequently get a few drops of water coming out where the steam control nob connects to the steam valve body assembly. This water drips directly down to the base of the machine, next to the boiler, at about the 10-o'clock position if viewed from above. Occasionally enough water comes out that it wicks around to the front of the boiler (6 o'clock position) and appears as bubbling water at the junction of the boiler and machine base. This only happens for me during the initial heating cycle, and the drops only come for a portion of the heating time. I presume it's from a faulty seal (part P23 on espressoparts.com), but it's never bothered me much so I just let it drop whilst heating, or I catch the drops with a rag. I missed it the first few times it happened, so I also was initially confused as to the origin of the water bubbling myself.
2. Water could leak out from the base of the boiler if not properly screwed down onto the machine base (also known as the heating element base not being screwed "up" into the bottom of the boiler). But, I think this is highly unlikely, particularly in a fresh-from-the factory machine. And, I think that'd tend to be a bigger leak. I'd put this as pretty unlikely, but possible. One way to check if to grasp the (cold) boiler and gently twist in a clockwise (when viewed from above) manner on the base--does it rotate? If so, we'll talk more.
Enough for now--let us know how it goes!
Pics are always great
Derek
