So I've had my Alexia/Macap M4 combo for about 2 weeks now and it has been amazing, and I'm slowly learning some of the the necessary steps to make a good espresso.
One adjustment that I am planning on making tonight is lowering the brew pressure...I don't know what to expect when I do lower it, but from what i've read I should be pulling shots at approximately 9-10 bars and right now my machine is pulling at 10.5. Can anybody offer me guidance on what pressure I should shoot for? I believe that in the HB Alexia write-up 9.5 was selected - has this been the "sweeter-spot" for others as well?
So, just to get an idea of what to expect, when I do go to adjust the OPV tonight, I plan to remove the rubber hose on the OPV before adjusting, and then will turn the nut counterclockwise...If I want to lower the machine by 1 bar of pressure, will this be an approximate 1/4 turn of the nut, or closer to a couple of full turns of the nut?
Thanks folks!
-Rob
