erics wrote:Cheerfully, I would not cut or grind/file away any part of the OPV spring until I had a new replacement spring in my hands.
Hola,
My same thoughts when I was confronted with this.
What I did to overcome this was just simply place the spring in a vice and tighten it to make it smaller.( No cutting involve), this worked for me.
I placed it back in the OPV and was able to dial it down. I have it set at 9.5 for my taste but some times I change it to 10 or 11.
Luckily I never had a low temp problem on my Venus. But I do get the "earthquake shake", my cups shake when the pump start.
I did some research on the unit before I bought it and I notice that they did have problems on older units with steam power but that has been fix according to the Isomac rep by my area.
I would recommend getting in touch with Jim @ 1st-line.
they are very helpful and a great place to buy from.
http://www.1st-line.com/machines/...d/isomac/venus.htm
"Now in stock and IMPROVED with a higher temperature steaming thermostat which will provide greater steaming power."
Hope this helps
Enjoy
Michael
