nicfortin wrote:Can you explain that a little more. I'm on the verge of buying the M4C stepless doserless. I don't see the advantage in home use for a doser beside having to clean it every other day...
And tell me how can clumping can be a problem if you use WDT?
nicfortin- see this
thread for some discussion of doser versus doserless.
I'll insert my comments here:
jesawdy wrote:I went doserless the first time, thought I had done enough research on that issue, and wish I had gone with a doser. As Dan said, and I maintain is not very clearly stated all that often, doserless machines make clumpy grinds that fall right into your portafilter. With a doser, those clumps get broken up by the doser vanes as you operate the doser with a rapid thwack, thwack.
With a doser, those clumps get broken up by the doser vanes as you operate the doser with a rapid thwack, thwack; This is a "feature" of a grinder with a doser... and it doesn't matter if you have 1 double a day or 12, I think it is an improvement over a doserless.
WDT is used to overcome a doser's clumpiness.... I do not use the WDT (have played with it), but find it wholly unnecessary with a my doser grinder. I can see the WDT's advantage, and probably should use it with my Rocky doserless, but I just spend a little more time on distribution with Stockfleth's, etc.
