PeterG generously agreed to a one-week loan
PeterG wrote:Do ya wanna borrow?
HB wrote:Do ya have to ask?
Nick wrote:Ummm, did you actually taste any shots?
framey wrote:Kind of brief for you Dan
HB wrote:What was a surprise to me, given my prior experience with La Marzoccos, was that the GS3 produces such good results with less difficulty then its siblings.
another_jim wrote:If you're in a debunking mood, Dan, or at least a tough one, serve some blind paired shots during your weekend jam.
miKe mcKoffee wrote:Might be nice to have both the PF and clear demi in the videos if possible.
HB wrote:If you're desperately looking for reasons not to buy a GS3, I would put poor ergonomics at the top of the list. Was the product designer left handed? Or is the machine's compact nature force compromises due to interior room constraints? The workflow from brew-to-steam is clumsy:And while not part of the ergonomics proper, the programming could be politely described as "Byzantine". I was able to piece it together with the help of Chris Tacy and Andy Schecter. Inexplicably, the least-often changed settings are first in the program cycling. Brew temperature is buried near the end... let's hope they revisit the ease of use in the production version.
- Steam arm is on the left, toggle control is to its right
- Brew controls are on right, opposite side of the grouphead.
- Steam arm doesn't reach the driptray (must purge into a steam pitcher)
Teme wrote:the production model's steam arm moves freely and can be placed over the drip tray
HB wrote:The arm rotates in a horizontal plane but is several inches above the driptray. I doubt they would want to make the steam wand reach lower than it already does. Despite the disappointing steam arm ergonomics, the quality of the microfoam is excellent. You would have to try really hard to screw it up.
another_jim wrote:Ashiness: Usually a flaw in rapidly dark roasted, low grown coffees. Drop the temperature to the low end of the espresso range. Dial in to the lungo end of the optimum crema range and dark stop the shot (you may be under 20 seconds when you do this, that's OK). These measures will not much reduce the ashiness, but will mask the problem with a little more brightness and crema. The real solution is to change blends.
HB wrote:If you're desperately looking for reasons not to buy a GS3, I would put poor ergonomics at the top of the list. Was the product designer left handed? Or is the machine's compact nature force compromises due to interior room constraints? The workflow from brew-to-steam is clumsy:This machine puts out a beastly amount of heat. What do Italians have against insulation, at a minimum for the steam boiler?
