Marshall wrote:I used them to pull shots, which is to say I hit them once to start the shot and a second time to stop it. :D
I programmed them to be 2.5oz volume, hit them to start and pulled the cup out when the shot was done. Worked like a charm.
jrtatl wrote:If the SERBC is held in ATL, will they have a judge's certification course? I'd love to take it and participate, even if it means eating bland food for a couple of days.
Ken Fox wrote:Have people forgotten that the great majority of what is going to be in yoiur cup is the beans you start out with, most of the rest in your grinder and grind setting, with a modest amount in your barista skills and even less in your machine?
Ken Fox wrote:Excuse me, but this thread is becoming a parody of what many of us think of CG. All this fawning over equipment at this level is somewhat nauseating.
AndyS wrote:Is this the same "Ken Fox" that:
- owns two $2500 espresso machines,
- exults at their improved performance after PIDing them,
- tinkers with internal piping to modify temperature profiles,
- obsesses over pump type, preinfusion pressure and rampup times,
- installs auxiliary pump timers,
- publishes thousands of words and dozens of graphs documenting their technical performance?
Couldn't be. This must be a parody of Ken Fox.
Marshall wrote:Ken, I hope you heard the sound of bitten tongues all over the Internet when you wrote that.![]()
This GS3 obsessing is like what you do when you order a hot car that won't be delivered for several months. All you can do until then is fantasize about how much fun it will be to drive.
Ken Fox wrote:A week after you spend your next car's downpayment, you will be rewarded with . . . . . a cup of espresso.
ken
Marshall wrote:This will be a huge bargain compared to my old senior partner's first $250,000 swordfish steak.
Nick wrote:Dan, my point was that the SERBC is not gonna be in Atlanta anymore. It will be back at Playmakers Repertory Theatre on the UNC campus.
Ken Fox wrote:Have fun in Chicago; hope you brought along a melita cone, given this recent picture of Jim's Isomac:
On a different note, what's wrong with using the automatic buttons on the GS/3? Other than it doesn't "look hardcore?"
AndyS wrote:Teme wrote:Jacob wrote:The brochure lists a couple of points where one says "Brew water pre-heating system".
Can anyone tell how this preheating takes place?
There's a heat-exchanger through the steam boiler.
And in addition, there's a hot/cold water mixing device. This ensures that any overheated water from the heat exchanger is cooled down before it enters the brew boiler.
Jacob wrote:Today I was told (by a technician from a La Marzocco selling shop) that there is no HX and that the brew water is just picked up from boiler itself![]()
Can anyone verify if it actually uses a HX or not?
Thanks
Jacob
miKe mcKoffee wrote:IIRC he's right and wrong. The group gets the water directly from brew boiler, ...
