One Way Valves and boiler feed lines
Link to "One Way Valves and boiler feed lines"by 2xlp on Wed Jan 10, 2007 1:30 pm
My Venus is in parts, and my expobar will soon be.
Looking at both, neither have a 'one way valve' leading from the pump to the boiler.
Should they? Regarding the designs on each, isn't the boiler pressure as it heats forcing back on the pump - even when its off? And the pumps are rated for ambient temps , doesn't this heat the pump to some extent?
2xlp
Link to "One Way Valves and boiler feed lines"by chardinej on Fri Jan 12, 2007 10:56 pm
My NS Oscar has a tiny one-way valve between the pump and the hot water system. The valve fits inside a brass fitting and you would never know it's there from the outside.
chardinej
Link to "One Way Valves and boiler feed lines"by erics on Sat Jan 13, 2007 8:20 am
The Ulka pump has a check valve built into the discharge port and some OPV's (e.g. Expobar) also have a check valve built into them.
See this: http://www.home-barista.com/forum...ry-pump-t1079.html
Here is a link to a beautiful description of the Expobar OPV as found on the Brewtus: http://tinyurl.com/ykgp4z
I believe this OPV has been improved since Sean L. wrote the above paper and the improvements were described by DaveC here: http://myweb.tiscali.co.uk/coffee...iles/OPV_Valve.pdf
Eric S.
erics
Return to Espresso Machines
