One small step...... Mazzer grinder sweeper mod
Link to "One small step...... Mazzer grinder sweeper mod"by IMAWriter on Sun Aug 21, 2005 9:53 pm
Thanks to Dan K's pix, i was able to do the "sweeper" vane mod on a Mazzer SJ...I actually used heavy duty velcro, cut and measured to hit bottom...i used only the rubbery "nubby" sides, stuck together...not the felt portion...makes for a stiff, very effective sweeper...now if i could just machine the width of the upper vanes a bit narrower....it's quite a resting place for grinds!
Man, this thing grinds fast!
IMAWriter
Link to "One small step...... Mazzer grinder sweeper mod"by HB on Sun Aug 21, 2005 9:58 pm
For those who are wondering what picture Rob is referring to...
Increase sweep efficiency by adding tape to the trailing edge of the Mazzer's doser vanes
Referring back to a post I answered on CG (link). As for the grinds ledge, check out the "Modifications" section of HB's handy Resources page.
Link to "One small step...... Mazzer grinder sweeper mod"by IMAWriter on Sun Aug 21, 2005 10:18 pm
Except MINE is less sticky! :lol:
Dan, thanks for taking all that time with me last night...you truly are the uber Geek
IMAWriter
Link to "One small step...... Mazzer grinder sweeper mod"by HB on Sun Aug 21, 2005 10:41 pm
Velcro or electrical tape? I've heard that the velcro develops a "coffee mustache", which isn't a problem with my proposal. The adhesive portion is folded onto itself, so there's nothing to stick to. It wears out after a few months though.
Link to "One small step...... Mazzer grinder sweeper mod"by IMAWriter on Sun Aug 21, 2005 10:57 pm
HB wrote:Velcro or electrical tape? I've heard that the velcro develops a "coffee mustache", which isn't a problem with my proposal. The adhesive portion is folded onto itself, so there's nothing to stick to. It wears out after a few months though.
Velcro..my is folded over as well, sticking to itself...only the rubber portion touches the grind....
BTW, there is a thin metal wire like thing sticking up, screwed in to one of the upper vanes...is that to relieve static?
there's a corresponding hole on the opposite side, but it's empty....
Missing the tray that goes on the bottom to catch grinds...no biggie, though
It ground a triple in around 10 secs...maybe a tick less..had tamper in throat....it really shoots the grind to the front side of the doser...
IMAWriter
Link to "One small step...... Mazzer grinder sweeper mod"by HB on Sun Aug 21, 2005 11:05 pm
That little wire sticking up from the end of a vane is to knock off the stale grounds from the doser's interior. It comes in handy at cafes that fill to the doser's brim. :shock:
PS: espressoparts.com sells the SJ tray separately. It's not cheap, but much bigger than the Mini (pseudo) catch tray and it looks sharp.
Link to "One small step...... Mazzer grinder sweeper mod"by IMAWriter on Sun Aug 21, 2005 11:12 pm
HB wrote:That little wire sticking up from the end of a vane is to knock off the stale grounds from the doser's interior. It comes in handy at cafes that fill to the doser's brim. :shock:
Another big thank you...I originally thought my cafe-owner friend was loaning me a Mazzer MAJOR...was surprised it was the SJ...I told her i would clean it up and sell it for her...not sure where/when they originally purchased...
It's scratchless except for a couple on left front...i removed the PF holder as well...easier with naked PF..edit..hee hee, and I ground vac this morning as well...no harder to adjust than my Rocky DL....I might see if she'll sell it (the SJ) to me...
I'd cut down the hopper, or get the mini cut down from chris...
Haven't peeked at the burrs as yet...chicken...i think theres's a screw stopping me from rotating it(the grind mechanism) completely off
edited for faux pas
IMAWriter
Link to "One small step...... Mazzer grinder sweeper mod"by skyryders90 on Sun Aug 21, 2005 11:59 pm
HB wrote:PS: espressoparts.com sells the SJ tray separately. It's not cheap, but much bigger than the Mini (pseudo) catch tray and it looks sharp.
Do you have a link to this? I can't find it anywhere, but would like to look into it as I think it would work well with my new Mini E Doserless.
Thanks!!
skyryders90
Link to "One small step...... Mazzer grinder sweeper mod"by HB on Mon Aug 22, 2005 12:29 am
No, I ordered it from Brian over the phone. I talked to Dave and he'll post the specifics.
Mazzer Grinder Trays
Link to "One small step...... Mazzer grinder sweeper mod"by OlywaDave on Mon Aug 22, 2005 6:31 pm
Yeah I talked with Devon and we quit carrying it as a separate item since it costs $50.00!!! The new Mazzers all come with one obviously, but we find that they really don't work all that well. You still end up with coffee outside the tray if you are particularly messy when you dose, which I have to admit I am since I over-dose and use the lid to scrape and distribute the excess grounds.
We actually retired the plastic tray that came with our Mazzer Mini, this is what we use and you might find it to be a little more affordable and useful.
http://www.espressoparts.com/product/tray
HB wrote:No, I ordered it from Brian over the phone. I talked to Dave and he'll post the specifics.
David White
EspressoParts.com
OlywaDave
Link to "One small step...... Mazzer grinder sweeper mod"by barry on Tue Aug 23, 2005 12:14 am
half-sheet baking trays work well under grinders.
also, the little trays from the mall food court work well....
barry
Return to Espresso Grinders
