One-Hole Blind Basket
Link to "One-Hole Blind Basket"by pannyd on Fri Feb 17, 2006 11:56 am
I recently found what looks like a blind basket but it has a single hole in the dead centre (it is smaller in volume than a single shot)
anyone know what this is ?
pannyd
Link to "One-Hole Blind Basket"by Reighlok on Fri Feb 17, 2006 7:58 pm
Could it be a pod basket with a built in "crema enhancer"?
Reighlok
Link to "One-Hole Blind Basket"by cannonfodder on Fri Feb 17, 2006 11:46 pm
Reighlok wrote:Could it be a pod basket with a built in "crema enhancer"?
That is the first thing I thought of. Some kind of pressurized pod adapter.
cannonfodder
Link to "One-Hole Blind Basket"by pannyd on Sat Feb 18, 2006 1:29 am
pod-adaptor ........sounds likely but are these usually polished smooth (like a blind basket) ?
pannyd
Link to "One-Hole Blind Basket"by erics on Sat Feb 18, 2006 9:20 am
Well, additional questions for you would be:
Where did you "find" it and what is the approximate size of the "hole" ?
Somebody could have been trying to simulate shot flow/pressure but that hole size is very small - around 0.012" and not easily drilled in the average home environment.
Eric S.
erics
Link to "One-Hole Blind Basket"by barry on Mon Feb 27, 2006 6:52 pm
erics wrote:Somebody could have been trying to simulate shot flow/pressure but that hole size is very small - around 0.012" and not easily drilled in the average home environment.
i made one several years ago for just such a reason. i ended up soldering the hole closed again as the rig was pretty useless as a single coffee ground would plug it up.
barry
Link to "One-Hole Blind Basket"by erics on Mon Feb 27, 2006 7:26 pm
Barry - you is definitely correct but should you get the "fever" again, these guys will hep you out:
http://www.okcc.com/catsub_precision.htm
Eric S.
PS - you just don't know how to grind fine enough (grin)
erics
Link to "One-Hole Blind Basket"by richl1 on Mon Feb 27, 2006 10:50 pm
barry wrote:i made one several years ago for just such a reason. i ended up soldering the hole closed again as the rig was pretty useless as a single coffee ground would plug it up.
I just made one by putting "JB Weld" epoxy on an extra single PF basket covering all but 1 or two holes. Just yesterday, it stopped working. I assume a stray coffee ground did just as you described.
I thought slowing down the flow would make it easier to flush the HX, but it did not have much effect.
Rich
richl1
Link to "One-Hole Blind Basket"by barry on Tue Feb 28, 2006 12:38 am
erics wrote:Barry - you is definitely correct but should you get the "fever" again, these guys will hep you out:
nah, i went the other way and found a filter to put before the orifice.
--barry "my contribution to the thermofilter"
barry
Link to "One-Hole Blind Basket"by erics on Tue Feb 28, 2006 12:40 am
"Just yesterday, it stopped working. I assume a stray coffee ground did just as you described."
You really wanted to say "it ground to a halt." Didn't you? Didn't you? ;-)
The slow flow (normal double-shot flow rate) heats up Silvia's brewhead far better than a high flow flush. The water has a very low velocity - 1.25 feet per second or thereabouts IIRC and that does wonders for heat transfer. I'm monitoring a couple of temps on my Silvia and flowing the hot water through the orifice provided a means of getting the girl up to temp very fast in the AM.
I don't do it too much anymore because she is now on a timer and the "normal flush" works just fine for getting her ready for that first double-shot in the AM.
Eric S.
erics
Return to Espresso Machines
