bill wrote:hperry,
I don't have a Cremina, but I think my Rivera and Elektra work in a similar manner. The system controls the temperature of the water in the boiler indirectly thru a pressurestat. When the machine is first turned on pressure tends to build up in the boiler, actuating the pressurestat, and shutting off the heater before the water has come up to the correct temperature. Releasing the pressure thru the steam value allows the water to come up to correct temp.
Hal -
I think that Bill is onto your problem - if your pressurestat is set too high - as in unrealistically high - when you use the 'approved' technique of bleeding off the false pressure through the steam wand you are allowing the boiler to reach full operating temperature which is being held too high by the pressurestat, and you could be seeing steam and spluttering like the HX 'water dance' from your grouphead.
When you do not bleed off the false pressure, you are in essence performing a sort of primitive (and uncontrolled) form of temperature management in which the boiler temperature has stabilized well below where the pressurestat is really set, but is now in the proper range for extracting espresso.
The simple test would be to locate an inexpensive electronic thermometer with a remote probe. Since if my theory is correct there may well be as much as 20 degrees temperature difference between the two states, the thermometer doesn't need to be particularly accurate or even fast-acting. Once you've got the thermometer, open up the case and find a spot to wedge its probe in close contact with the boiler.
Bring the Cremina up from cold, but do not blow off the pressure bubble - note the boiler temperature after 5, 10, and 15 minutes - it should be pretty stable, and run somewhere between 198-210 degrees F. Now, blow off the pressure bubble by using the steam wand and again note the boiler temperature at 5 minute intervals.. My hunch is that the temperature will rapidly rise to well over 212 F, and may stabilize at as much as 220-225 F.
If your pressurestat is set too high, you can use the thermometer to adjust the temperatures by carefully lowering the pressurestat (I think it lowers by turning the screw counterclockwise) by less than a 1/4 turn - steam or flush until the the temperature drops and the element comes on, then note the new temperature after the boiler stabilizes.
It's a fussy, painstaking process, but you should end up with the boiler stable at something like 212-216 which should give 205-208F at the grouphead - which I believe is about right.
The best way would be to tee in an actual pressure gauge - I think Steve R. has a thread on how to do this, it's a fair amount of plumbing, but is very accurate. I also think that Home Espresso Repair may well have a pressure gauge setup for the Cremina and can set the pressurestat for you id you confirm it's set too high.
Cheers
Dr Jim
