by mogogear on Sat Apr 19, 2008 12:25 am
If "coffee / espresso / water leaks into your cup before you have started to pull down... , while you are waiting for the puck to moisten- -----You most likely have one of the following needing attention:
1.Not really fresh coffee- I mean fresh - not grocery store bought - with in a week to 10 days from roasting preferably - Older coffee is dried out and won't resist the water and boiler pressure( which is not substantial - about 16-18 psi)-- and not pre-ground!
2.Grind not fine enough- I hope you have a decent burr grinder- nothing whirly- !! Find the grind that chokes your machine and back off slowly till you get there
3.Tamp / puck disturbed so seal is not in place.. Try to eliminate any random "knocking " etc while locking the PF into place, after you get the coffee tamped.
4.Not enough coffee in the basket- for a double you should have about 14-16 gm of coffee - leveled, distributed uniformly, tamped .
This is a simplified version of what I do: Just a few places to check out your routine !! And once you can lift the lever and let it stay in place with no drips, and then you ever so lightly apply the weight of your hand for about... 5 seconds... then re-lift to re-charge the fill above the puck-- The start your pull...slowly and lightly at first - till the drips count to about 10, then ramp up the pressure of your pull, and maintain till the end..Drink!
The finished puck result will vary with your brewing process. Practice will make perfect.
Getting in tune with your routine and your Cremina just takes time-- so enjoy the lessons - it will be about 3-6 months for the average person to settle down and just see what works with in the general guidelines you will find on this wonderful site!!
ciao!
greg moore
Leverwright
LMWDP #067
