Olympia Cremina 67, the last year the boiler had asbestos?
A haven dedicated to lever espresso machine aficionados.
Link to "Olympia Cremina 67, the last year the boiler had asbestos?"by Fullsack on Wed Feb 07, 2007 7:33 pm
It was my understanding, the last year the Cremina had asbestos around the boiler was in the 70's, but I just saw an '81 with an asbestos boiler insulation. Could this machine be a melange of more than one machine?
Doug Jamieson
Full Sack Jack Coffee Roasters
LMWDP #017
Fullsack
Link to "Olympia Cremina 67, the last year the boiler had asbestos?"by timo888 on Wed Feb 07, 2007 7:58 pm
I don't know when Olympia stopped using asbestos to insulate the boilers on the Cremina, but the asbestos litigation didn't get into full swing here in the States until the 1980s, so I would not be surprised to learn that asbestos was still being used on Creminas dating from that period.
I am not advising removal of the asbestos, but if one were going to do it, the asbestos on the boiler should be misted gently with a spray bottle until it is very wet and then the boiler should be gingerly removed and thoroughly soaked in a bucket of water overnight. Then you can scrape the asbestos off. Keep the asbestos very wet, and bag it tightly in plastic afterwards. A one-time exposure might pose a negligible health risk (though that is open to debate since there are incidents on record of single significant exposures causing asbestos-related lung disease), but if the fibers should become airborne in your home, the contamination could reach levels that exceed EPA domestic guidelines, and this could require expensive remediation before you would be able to sell your home, whatever the health risks might be. It depends on whether your buyer demands a test and what local regulations require. The shed or back yard on a windless day are better than anywhere in your home.
Regards
Timo
timo888
www.vanelis.com: top-notch espresso equipment and customer support
Link to "Olympia Cremina 67, the last year the boiler had asbestos?"by ladalet on Fri Feb 09, 2007 8:04 pm
My Cremina is an "83" and still has asbestos on the boiler.
Lance Goffinet
LMWDP #019
ladalet
Link to "Olympia Cremina 67, the last year the boiler had asbestos?"by Fullsack on Sat Feb 10, 2007 2:02 am
ladalet wrote:My Cremina is an "83" and still has asbestos on the boiler.
Then sometime in '83 they did away with the asbestos because one of my machines, the '83 #8324562, does not have asbestos on the boiler and from what I know of its history has probably never had an asbestos wrapped boiler.
Doug Jamieson
LMWDP #017
Fullsack
