puchang wrote:DaveC,
You might be onto something. I descaled the HX last month and after that the rattling sound seemed to go away for several days and then came back again. I read your article of the OPV last week. I took off the OPV on my machine and gave it a good clean but nothing has changed. Anita and Andreja Premium do have the same OPV and mine looked pretty clean under inspection. You mentioned the anti backflow valve in your post. Can I clean it as well? Is it the copper tube-like thing after the pump? I hope it is not related to scale because I used only treated water as I mentioned in the first post. My tap water is not hard either. Just a little bit more than 3 grains. I suspect my machine should be able to do fine even if fed with water at that level of hardness, right?
puchang
I dunno what grains are in UK speak. just sometimes these valves get sticky and running a bit of citric acid or similar through them can often clear them out, even if it's not scale, there can be other deposits. if also your are is like the UK, hardness can vary from time to time.
Easy way to check if it's the OPV, close it right up so that the machine is delivering 15 bar (NOT 9 or 10), and pull a shot with some coffee. This will mean that through a normal coffee puck (DONT change the grind), you will still only get whatever pressure your getting (say 10 bar), but the OPV will hopefully NOT try to open, or if it does, may be less inclined to "flutter".
If you do this TEMPORARY check and the noise changes markedly or goes away entirely, then you know the noise is coming from the OPV. Obviously set it back to where it was (you did count the turns)
The decision then is
1. Possibly you may have to live with it (cos it's mainly irritating, but not damaging anything)
2. Find out if air is getting in (descale brew path)
3. If you have an inline softening filter attached to the end of your water pipe (the one that sits in the tank (remove it, I won't go into details, but I hate them), if it's plumbed then don't worry about it.
As a last resort, I guess you could change the OPV (it's unlikely, but mebbe the rubber pad thing has fallen off, or a bit has broken off and your getting the clatter of metal to metal, or there is a high spot somewhere), or a new OPV could just be quieter.
Sorry about rushed reply, but not much time at the moment.
P.S. If you have got air into the system, it can be difficult to dislodge sometimes, running the pump for 20 secs, then off then on for 12 secs then off may gradually move the air out.
