Odd Expobar problem - no thermosiphon - Page 2
Link to "Odd Expobar problem - no thermosiphon"by jrd1955 on Sat Aug 30, 2008 3:37 am
CrackAddict wrote:
BTW - as a bit of introduction - I'm a Canadian, married to an American, living in London, UK. As my interest in coffee has grown, I have scaled (no pun intended) my equipment up, but I feel a bit restricted by the knowledge that some day I will move back to the US or Canada and all this 220/240V, 50 Hz equipment will be on eBay. I settled for the Expobar Office Control as it was a very good price in the normally overpriced UK market. (Think same number in GBP as in US$ - about 80% more... for a product made closer to home.)
Perhaps in retrospect, I should have gone with a non-electronic (i.e. lever) controlled machine as it's relatively simple to provide 220V power in a US/CDN residence (like an electric dryer) and only the pump in a lever machine is likely to need to be changed for the North American 60Hz supply. I know - another thread, another time!
I'm having a similar problem with my 3-year-old office control. When making a shot, the pump operates for a long time, but water does not come from the group head. As a temporary fix, after filling the porta-filter with coffee, we run the pump for awhile until water comes out, shut the pump of then we insert the porta-filter and pull the shot. Works very well, but I would like to get this working properly. I suspect a stuck valve somewhere and am reading these posts to figure it out.
I should add that at times, the pump runs for an extremely long time (> 20 seconds) when we first power the machine on in the morning, after the machine has been sitting on, but unused for awhile, or, as I said, when pulling a shot. Note that this is more likely to be true if we haven't made a shot for awhile.
In the meantime, it may interest you to know that I am from the US, and own a 120 v machine. I have been living in Italy for the last 18 months and am using a step-down transformer. The pump has worked fine at 50 hz. It was a risk, but we took the chance and it seems to be fine (apart from this quirky problem we are having as of recently).
Jim De Piante
jrd1955
Link to "Odd Expobar problem - no thermosiphon"by jrd1955 on Sat Aug 30, 2008 4:04 am
Skealoha wrote:CrackAddict,
I'm going to try working cleaning out the OPV this evening, but now I'm sure the pressure will be out of whack. I'll have to count the turns on the screw I guess. Another $51.00 and I can buy the pressure gauge/portafilter from Chris's Coffee too :D!
So did you ever get it fixed?
Jim
jrd1955
Link to "Odd Expobar problem - no thermosiphon"by ira on Sat Aug 30, 2008 12:16 pm
CrackAddict wrote:Tell me - does your machine take a long time to "pump up" in the morning when you turn it on? By that I mean does the water pump run for 20+ seconds on power-up?
My Brewtus does that. I think it's because when you turn it off the boiler is full of boiling hot water which shrinks when it's cools off then it takes quite a lot of water to fill it up cold. Once hot it takes quite a lot of steam before the pump runs the first time as if the water expanded and it's slightly over full, but after that it runs more often.
Ira
ira
Previous
Return to Espresso Machines
