by aindfan on Fri May 09, 2008 1:22 pm
If you're going for doserless, I'll put in a good word for the Le'Lit. I don't know much (anything) about the MCF, but with the Le'Let you're stuck with your espresso grind unless you want to turn the adjustment knob about 100 times (from what I've read) to get to french press. I am very happy with how stepless it is: one turn of the knob still makes a fairly small change in extraction time (couldn't tell you exactly how much, maybe others can?). Another note: when I grind into my PF I use a bottomless yogurt cup in the basket and surrounding the grinder spout to prevent the grounds from spraying outwards, because, as the pile gets higher in the basket, things start to get a bit messier. I also knock on the spout after grinding to get every last bit out of there, but that's just me.
Good luck with the decision!
Dan Fainstein
LMWDP #203
