1500 watts / 15 amps
97 pounds
direct plumb / rotary
preinfusion
volumetric dosing
WOW! $2500 from Chris.
joatmon wrote:5 liter boiler
97 pounds
preinfusion
volumetric dosing
Marshall wrote:This is the same machine the NS rep in Charlotte told me would list for $3,700 in the U.S. (and wouldn't arrive here until the Fall). Chris may be running an introductory special. If you have the counter clearance (it's really tall), it's definitely worth a look, especially if you don't change temperature very often.
joatmon wrote:Why not good if you change temp often? Are most/all HX machines easier?
Marshall wrote:The Aurelia depends on a clever system of hot and cold water mixing to maintain its temperature stability. Temperature is adjusted by opening up the machine and swapping gicleurs. There is no simple external control. This works nicely in a commercial setting that always brews the same blend. But, at home it would be a much bigger pain than punching numbers into a PID.
joatmon wrote:You refer to the Aurilia as though it is the same as the Appia. Is it? I understand that a gicleur may be simple to replace. How is it on the Appia?
Thanks,
Jack
Marshall wrote:I don't know. Ask Chris.
joatmon wrote:Good suggestion.
I called Chris and spoke with Mary. She said the Appia's temp is controlled by going inside the machine and adjusting the Sirai pressure stat.
Jack
Marshall wrote:That's what p. 36 or the owner's manual says: http://www.nuovasimonelliusa.com/images/Appia_1_group_manual.pdf. But, that's also what p. 12 of the Aurelia manual (same site) says, while everyone else is talking about gicleur adjustments. The manuals also say that pressurestat adjustments should only be made by "a qualified technician." It sounds like NS isn't eager to have end users tweaking the machine.
You are totally beyond my experience at this point, as I have been relying on third party reports and salesman talk in Charlotte. The Appias have just arrived in the U.S., so it may take a while to get a handle on how stable and adjustable they are.
HB wrote:Calling it an "HX machine" seems like a misnomer; apparently it's so large, it could be rightly called a second boiler (don't quote me, but I think its volume is almost as much as the GS3's dedicated brew boiler). Since the HX is so large, incoming water doesn't have a dramatic effect on its output temperature. The HX's output water is mixed with unheated water to arrive at the desired brew temperature. As reported earlier in this thread, swapping in a different mixing valve changes the proportions and the resulting brew temperature (the owner's manual only talks about tweaking the pressurestat; we did not measure how much effect that would have).
Marshall wrote:NS describes both the Aurelia and the Appia as having a "thermocompensated" group. http://www.nuovasimonelliusa.com/images/appia_1_group_bochure.pdf. If that's what they call the mixing system, this machine could be an amazing value for anyone who has the counter space.
woodchuck wrote:Not sure this is the best place for this post but here goes. I had a chance to play a bit with the Aurelia on Friday at CCC. Dan was there and after a couple of attempts pulled some very sweet shots of CCC's latest Toscano +++. Thing is he pulled about six or seven shots - none bad and all with a very deep, dark crema and lovely berry flavour. I pulled a couple after Dan and the coffee geek crowd left. Took a bit of work but with a little updosing managed to get some nice rich chocolate, an initial hint of fruity cranberries and a great finish. I took the same grinder and beans went back to CCC's La Marzocco three-group and I could not recreate the really soft, rich front end. A much brighter shot and the color of the crema was much lighter. Not too scientific a post, I have no idea what the machines were set at pressure and temperature wise but I sure was impressed with the Aurelia.
gscace wrote:FWIW, the LM 3 group that was in the training lab at Counter Culture ran very cold during the my demonstration of the Scace device at EspressoFest this last spring.
another_jim wrote:Micheal says that "thermocompensation" is an effect most thermosyphon machines, including the E61, both manual and solenoid, use. It means that some cold water makes its way up the thermosyphon return at the shot's start and tempers the initial in-rush of overheated HX water. In the Aurelia, this is well tuned, I suspect it was on real Faema E61s, including the classic, because Steve Schulman has pulled me lots of shots (a daily thing at the SCAA convention), and I've never seen him flush. I suspect that home e61 boxes don't have the all the parts required for this sort of tuning.
