This weekend I've been browsing the old topics and playing with my recently received Anita and Mazzer and had a few questions.
Mini:
1. I was trying to find the "zero point" but wasn't sure if I really found it. Turned on the empty grinder and slowly adjusted the collar until I heard what appears to be the burrs touching. The sound reminds me when you get a key made, so I assume this is it? I didn't want to go any farther for fear of damaging the burrs.
Anita:
Initially the brew pressure was very low (4.5-5 bars) when brewing a shot so I tightened up the grind on the Mini to just above the zero point. I lowered the brew pressure from ~10.1 bar to 9.6 bar (measured with the blank). This seemed to improve the taste of the espresso. The puck is more damp compared to when the pressure was 10.1 bar.
2. When pulling the shot, the pressure went to about 8 bars during the pull then maxed out at 9 bars when I pushed the lever down (about 15 seconds for a 2 oz extraction). Is this normal? Is the pressure still too low? The grind is just above the zero point.
I've been doing the "water dance", and the coffee is a French Roast from Whole Earth foods.
TIA.
