momo73 wrote:The machine is like new, but old. What happens is when the lever is lowered, and the rubber seal that is supposed to drop and let water into the chamber, well the rubber disc stays closed and doesn't let water into the chamber. I have used a long thin metal rod to push the rubber down, then the machine works. I think that because the machine has never been used, and the rubber has been squished closed under pressure for so long that it might be a little distorted. Where can I find a new rubber seal????
Ciao
Mauro
The rubber washer in the ceiling of the piston chamber has probably stiffened with age. It needs to flex, as you have seen for yourself. I am restoring a La Peppina now, and have had to buy o-rings of various sizes as well as several sizes of washers, all in considerably larger quantities than I will need. It was impossible to find exact matches for the washers so I'm having to improvise and experiment. There's also a small washer behind the dispersion screen that prevents brew-water from being sucked back into the piston chamber. If that stiffens, you could get rancid coffee oil building up in the channel.
In a couple of days, after I have determined which ersatz washers work best, I will put little Peppina restoration kits up on eBay, including a nifty brush to clean out the channel between the piston chamber and the group. I have not attempted to replace the rings inside the group, only in the piston and the seal between boiler and heating element, and the two one-way valve washers, so the kit won't contain those group seal rings for now. Nonetheless, the kit will be a great bargain compared to what you'd have to pay to buy your own large quantities from various sources.
At the moment (19 April 06) I have only the piston and boiler o-rings available on eBay. Wait for the washers and the brush.
Regards
Timo
