I am in the midst of writing a review of the Gene Cafe, so my brain is feeling a bit roasted, but I will try to answer:
luca wrote:OK, so let's say that instead of dropping at 166F, I want to drop at 350F. I just let the roaster run until it hits 350F, then dump my beans and continue to roast as normal, right?
I assume that we are discussing the KN-8828B (the newest model). Reading your post carefully it seems that "dump" means pour the beans into the roaster to begin roasting. If you want to get a shorter roast by adding the beans later in the roasting cycle when the machine is hotter, that can be done without a problem, but remember that no electric roaster can roast faster than having a 100% heating element duty cycle. That is, if the heating element is on all the time, that is as fast/hot as it can roast. So even if you add the beans later in the roast cycle when the heat in the chamber is higher, the temperature will drop dramatically and then have to heat up again. Beyond that, the hotter the chamber the greater the risk of tipping or scorching the surface of the beans. There is also the problem of leaving the center of the beans less-roasted than the outer portions if you start too hot and end too soon.
And from what you have said, if I want to roast two batches back to back with a 350F drop temperature, I have to do the first batch, then wait for the roaster to cool, then heat it up again. Is that right?!
Yes. The machine always starts at the same point of about 166F. If it senses that it is hotter than that when you begin a roast the machine will go into an extended cooling cycle until it hits about 150F and then it will begin the preheating. This is to establish a consistent starting point for every roast.
Is there a safety time limit that the roast must be completed by? If there is, is there any risk that dumping after an extended preheat would make the roast time needed run over the time limit?
You can add the beans at any time you like, but once the roast begins (after the cooling cycle completes), regardless of when you add the beans, the roast cannot go for more than a total of 25:00.
if you are looking for more manual control and what a roaster to work as YOU wish, regardless of the outcome, I suggest getting the basic model and hacking it. The control panel can be removed and the ribbon cable used to control ALL functions of the roaster it is easy. Black is common, and red is hot. Jumping RED to each of the remaining wires will operate the various roaster functions:
-Heating element
-Drum Motor
-Cooling fan
-Main fan
-Eject solenoid
The use of toggle switches and the addition of a thermocouples to monitor chamber temperature and bean temperature would be all that was needed. Other than that, the new "B" model basically supplies those functions if you aren't too annoyed by the auto cool/preheat. it also adds control of the heating element in 10% increments and main fan control in 25% increments.
Am I getting closer to an answer?
