cannonfodder helpfully wrote:Welcome
cannonfodder helpfully wrote:The new model (referred to as the millennium group) uses a 51mm tamper. The older units used a 49mm tamper. You basket may measure 52mm at the top, but if look closely, you will notice that the sides of the basket taper in ever so slightly. You would have to measure the baskets internal diameter about a half inch down from the basket top. This is where your tamper piston will be when tamping. You can get custom turned pistons for your tamper, but for now stick to a 51mm.
Convex of flat, personally I use flat because the shower screen on the La Pavoni is flat. That keeps an even headspace across the puck. My pump machines have convex shower screens so I use a convex tamper on them. If you read the tamper road show thread than you should have seen the 'flat or convex' section in my review.
cannonfodder helpfully wrote:Bottomless portafilters are an indispensable learning aid. Personally, I would get one. That way you can see defects in your grind/dose/tamp technique.
cannonfodder helpfully wrote:I have not used the KA pro grinder so I cannot comment. Mark (coffeekid) has positive comments about it.
cannonfodder helpfully wrote:I don't live in philly but our corporate office is in West Conshohocken so I do get out there now and then. I know there are two locations in center city I have heard about but never visited. You can also order fresh beans from any of the HB sponsors, you wont be disappointed.
cannonfodder helpfully wrote:Finally be patient, lever machines are difficult to master. I wont pull any punches, it will probably take you around 3 months to get decent espresso, 6 months to get consistent good espresso and a year to reach nirvana.
mr. brown helpfully wrote:Hi Dan,
I'm a La Pavoni Professional owner who uses a 51.5mm Reg Barber tamper and who lives in Philadelphia. Fancy that... No KitchenAid though.
I personally like La Colombe's Nizza blend. It is usually very fresh (the secret is to ask them for a half pound so they have to scoop out the fresh beans behind the counter, and not just sell you whatever they have had sitting out up front). It seems like the most balanced of the locally available coffees in terms of flavor, and it doesn't suffer from the super-oiliness of the Old City Coffee espresso blend offerings. If you want to try something else, I recommend going out to Old City Coffee (Reading Terminal Market and Old City). They will have a better selection of single-origin coffees and also offer a regular and six bean espresso blend. I don't care for either of their blends (but that's just a matter of taste). Don't bother with Torreo coffee as it has probably been sitting around for quite a while wherever I can find it.
It is difficult for me to receive coffee in the mail, so I haven't done much of that. I did have a pretty lousy customer service experience with the owner of Cafe Fresco, so even though they seem to be everyone's favorite around here, I'd check out everyone else first before going back to him. Intelligentsia and Coffee Emergency could deal with getting mail to Philadelphia.
Mr. Brown
cannonfodder wrote:I am not a big fan of clicker tamps. If you read the tamper road show thread you may notice that there is little to no mention of the click tamp. While learning, use a bathroom scale. Just put a towel over the scale and tamp on it. One thing to keep in mind, the 30 pound rule is not. Think of it as a guideline, the key is consistency. If you use 10, 30 or 70 pounds, just be consistent.
I can not help much with the grinder adjustment. I have never used the pro line. I believe there are some threads about it on CG. I would suggest you do a search or start a new thread about it.
As to the cafe's, there is a thread on the CG US East forum about coffee shops in your area. I am sure they also sell beans.
bobcraige wrote:I would not purchase a bottomless portafilter. While they may be of great help on pump machines, lever machines have more than enough for you to master without trying to watch the flow distribution at the same time. Concentrate on the other items on your list and put the cost of the bottomless portafilter to better use.
Madroaster wrote:No, I say get a naked pf.
junkdan16 wrote:Yes, I think I may.
I'm a little concerned because my shots appear to be very short. This may just be a limitation on the machine, as I would imagine there is only a limited amount of water that can be held in the grouphead and cylinder before pushing down on the lever.
Also, I think I may have broken my grinder, so I'm going to have to replace that.
Has anyone attempted to contact Reg Barber customer service? I have sent multiple emails inquiring about the engraving (had to go for it) on my new tamper, but have received no reply. Has anyone had a positive customer service experience with him (them)?
Madroaster wrote:You're right...Europiccolas hold less water than larger machines, but the shots they produce are no lesser for it. Ristrettos often come in at far less than an ounce, but they're like drinking buttery creme. I'd imagine a normal shot is in the vicinity of 1.0-1.25oz, but someone may correct me on this. I don't really measure.
Madroaster wrote:I'm really sorry to hear that. What happened?
Madroaster wrote:I've had good experience with Reg. Remember, he's not a sprawling multinational corporation...he's pretty much a guy with a shop. He could be backed up, or even on vacation. Have you tried calling him?
