by da gino on Fri Jul 25, 2008 8:24 am
Hi,
I have had a pavoni for about 3 years and have gotten great results from darker roasts - and I've been roasting my own and producing very full bodied shots. Whenever I use a light (or perhaps even medium) roast, however, my coffee turns bitter. I have a fresh batch of black cat (roasted 3 days ago) a friend brought me and I just can't produce a very good shot. (She, however, is getting good shots out of a good pump machine with the same coffee - I haven't tasted them, but she says they are great and I believe her). I'd love to be able to produce good results from these coffees, too.
I should mention that I'm using 2 day old Macap m4 stepless and I'm still searching for the exact right grind/tamp and also I'm using a chopped portafilter. The crema being produced is visually stunning, but obviously that is secondary when the coffee doesn't taste good. Looking up at the bottom of the portafilter
doesn't show any of the problems from the photos on the chopped portafilter how to on this website (I would say the color is light brown and not red, but not blonding either).
I normally don't make more than 2 shots at a time, but obviously that limitation is a bigger issue when I'm trying to figure out how to go from sink shots to god shots!
Here is my usual routine..
1) Lift handle to pre-infuse for 10 seconds (depending on grind/tamp either the drips start after 5 seconds or don't start until I lower the handle).
2) I pull the handle down which takes about 14 seconds (with a dark roast it seems like if I don't pull through at this speed, it is more likely to be bitter - with my old grinder/grind this took medium force - I'd guess 15-20 lbs of pressure - with the new one it has varied from there on up to almost choking the machine)
3) The coffee continues to flow for a few more seconds so the entire shot including preinfusion, the pull, and the lingering after the pull takes anywhere from 25-32 seconds depending on when I pull the cup away.
With dark roasts, this process produces fantastic coffee that is full bodied and has lots of crema, but again with lighter roasts I've tried altering all these things a little bit without much success. Any advice on what try or change is welcome! I figure finally having a really nice grinder means I should be able to pull this off!
Hugh
