I just replaced some rubbers in my E61 grouphead, and it doesn't work
I think I have replaced the rubbers and screwed everything back correctly. Just now, when I do a backflush and there is pressure built up, when I move the lever down, nothing happens. Only when I pull the lever up (halfway is enough) and down again, water splashes out. It now needs that second lever movement
Also, when I do a backflush, but there is not that much pressure (when pulling the lever down too quickly) it will let water out! So it only doesn't work under pressure. It has something to do with the shafts and spring, for sure, but I can't figure out what. Does anybody know what I did wrong?
Thanks in advance,
Matthijs
Edit: Am I talking about the "pressure release valve"??
