Need dispersion screen for an Olympia Cremina 67
A haven dedicated to lever espresso machine aficionados.
Link to "Need dispersion screen for an Olympia Cremina 67"by brentlewiis on Wed Jun 20, 2007 11:20 am
Hey there...
I am in need of a dispersion screen for an Olympia Cremina 67 which I am trying to return to working condition. Does anyone out there have any idea where I might be able to buy one? I have tried Home Espresso Repair in Seattle, Rudy's L&R in NY, and 1st-line with negative results, and Olympia has not replied to my email. I am hoping to actually use this machine but am coming up empty with regard to this one part(a new gasket set would be nice, too). Any information or assistance would be greatly appreciated.
brentlewiis
Link to "Need dispersion screen for an Olympia Cremina 67"by Cathi on Wed Jun 20, 2007 11:47 am
H.E.R. should be able to help you out with gaskets. I also remember seeing them on occassion on ebay. Not "official" Oly parts, but will fit.
Cathi
LMWDP #113
Cathi
Link to "Need dispersion screen for an Olympia Cremina 67"by bobcraige on Sun Jun 24, 2007 5:57 am
The Cremina 67 dispersion screen is no longer available.
Bob Craige
LMWDP #7
bobcraige
Link to "Need dispersion screen for an Olympia Cremina 67"by mogogear on Sun Jun 24, 2007 8:10 pm
Could La Pavoni dispersion screen be brought in as a pinch hitter? Maybe change group head gaskets too?
greg moore
Leverwright
LMWDP #067
mogogear
Link to "Need dispersion screen for an Olympia Cremina 67"by bobcraige on Mon Jun 25, 2007 9:32 am
brentlewiis wrote:Hey there...
Do you not have the screen, or is it just very dirty? If you don't have the screen, it is a problem as it is no longer available. If it is just dirty, you can and should clean it up. In extreme cases, an ultrasonic cleaner, brushing and long soak periods can help get it clean. Don't give up on it if is only dirty.
As to gasket sets, see my post:
http://www.home-barista.com/forum...s-t4314.html#47465
Bob Craige
LMWDP #7
bobcraige
Did you ever find one?
Link to "Need dispersion screen for an Olympia Cremina 67"by raycam on Mon Aug 27, 2007 12:25 pm
Did you ever find a source for the Cremina dispersion screen? I need one also.
raycam
New Oly screens!
Link to "Need dispersion screen for an Olympia Cremina 67"by espressme on Mon Aug 27, 2007 6:36 pm
raycam wrote:Did you ever find a source for the Cremina dispersion screen? I need one also.
FWW.
Well, I just collected and drew up all the dimensions of a Cremina screen. I believe that I might make one from a LaPav 49mm Europiccola or Microcasa A Leva" screen.
It will take some time to make the steel metal spinning tooling. Both screens are larger than the Cremina. That is a plus, really! The "a Leva" has a blank spot about 1CM in diameter in the middle of the screen.
I would guess that the modification cost would be about $20 over the cost of the donor screen. Let me know if there is an interest. and someone willing to donate a trial screen.
sincerely
richard
richard penney LMWDP #090,
espressme
Link to "Need dispersion screen for an Olympia Cremina 67"by Cathi on Mon Aug 27, 2007 9:31 pm
Richard, I don't have a spare to donate, but I would be interested in getting on the list for a replacement. Many thanks, Cathi
Cathi
LMWDP #113
Cathi
Link to "Need dispersion screen for an Olympia Cremina 67"by jameseric on Sun Sep 16, 2007 5:37 pm
espressme wrote:FWW.
...might make one from a LaPav 49mm Europiccola or Microcasa A Leva" screen.
It will take some time to make the steel metal spinning tooling ...would guess that the modification cost would be about $20 over the cost of the donor screen. Let me know if there is an interest. and someone willing to donate a trial screen.
sincerely
richard
Hi Richard,
Any takers yet on the dispersion screen adaptation for the Cremina? Have just sent for a MCaL screen from 1st Line. I'm willing to be a test case here; let me know the protocol for payment and such.
Eric
Eric
LMWDP 0038
Cappuccino at Sisteron cafe
jameseric
Cremina screen
Link to "Need dispersion screen for an Olympia Cremina 67"by espressme on Sun Sep 16, 2007 6:30 pm
Hello Eric,
I have been swamped but shall try to get back to it after the next weekend.
sorry :(
richard
PS, the one I got had a non punched area in the middle about a cm in dia / 3/8ths" and I don't know if that was supposed to be. Please let me know when you get yours.
jameseric wrote:Hi Richard,
Eric
espressme
I'm interested
Link to "Need dispersion screen for an Olympia Cremina 67"by raycam on Tue Sep 18, 2007 8:57 pm
I'm definitely interested whenever you are able to do this.
raycam
Link to "Need dispersion screen for an Olympia Cremina 67"by espressme on Tue Sep 18, 2007 9:25 pm
Sometimes the body does not agree with the mind ( as if I had one.) :roll: Working on custom stuff and school projects does stretch a new project out. I need 8 unbroken hours to do the tooling and I haven't seen that lately. The tooling has to be accurate and removable from, and accurately replaceable into my metal lathe.
I do want to do the project!
So I shall let all know when the prototype is done.
I well know that waiting for significant parts is a #$%^&*(.
Cheers
Richard
raycam wrote:I'm definitely interested whenever you are able to do this.
espressme
Replacement screens for Cremina.
Link to "Need dispersion screen for an Olympia Cremina 67"by espressme on Fri Sep 21, 2007 10:58 am
Don't look now! It werkz. :shock:
First pull of the modified MiCal screen. That is the the original Cremina screen beside the cup
This project needs more trials of the screen tooling to assure a good fit every time. I had to do a bit of tweaking by hand on this one to get it tight. Still a tiny bit loose but no grounds inside when I pulled it off..
The first one goes to the person opening this thread if he will contact me.
Brent, are you there? :?: Edit= 9-26 I believe this project has come to a point that further contact would be by private message. The plan is to make available the rework of each MCal screen on a one at a time basis and make none ahead. Perhaps we may place this information into the Cremina parts sticky at some time in the future. :?:
Cheers!
richard
espressme
Link to "Need dispersion screen for an Olympia Cremina 67"by mogogear on Fri Sep 21, 2007 10:43 pm
Careful- Richard! That site glass on Cleo looks low! :wink:
Another good job! You da' man!
greg moore
Leverwright
LMWDP #067
mogogear
