by peacecup on Fri Aug 29, 2008 4:03 pm
1. Unplug the machine!
2. Open the filler hole and use a funnel to fill the machine. You should not fill it above the level of the sight glass.
3. On second though, fill it halfway, replace the cap, shake it a few times gently, and turn it upside down into a white bowl. If you see a lot of flaky stuff, its scale (hard water leaves this). You'll need to read up on how th clean it, but I guess you can try it. If its very scaly, you risk forcing the dirt into the piston when you use it.
4. No scale, refill the machine replace the cap, and plug it in.
5. Turn it on, but leave the steam valve open a bit - WATCH IT, so when it starts to sputter you can close it,
6. The little round light is the ready light - it will go off (I think, unless yours is reversed) when the machine is ready.
7. When its ready open the steam valve once - steam should come out and the ready light come on again for a minute.
8. Put the portafilter in and pull the lever down - water should come through it into the cup.
9. Fill the basket with coffee, tamp, lock in the filter.
10. Pull the lever down, wait 10 sec., and let the lever rise.
11. You should have espresso. For a double basket I take a second pull, without the 10 sec. wait.
Let me know how it goes.
PC
LMWDP #049
