Heat should not be an issue, as the unit currently turns only 60 rpm. An informal timing shows that a human can crank easily twice that speed. After 10 full minutes of operation at that speed, with the blades touching, they are still nearly dead cold.
Increasing the rotational speed should also speed up the grind time, so I will try this.
The unit, as built, contains an Oriental 2RK gearmotor (6 watt) with a gear reducer that turns the Zass at 60 rpm. The Oriental Motor series is very versatile and has more than a dozen gear reducer ratios. They also make speed control motors in the same size, which would give infinite control.
The "slot drive" consists of a double clamp collar with a hole drilled through it with a loose fitting 1/8" pin inserted through it.
The pin engages a 5/16" shaft that has been slotted to receive the pin. This allows the pin to be lifted to allow removal of the Zass.
The lower end of the shaft has a pin pressed through it to drive the aluminum rod which contains a 10 mm nut pressed into its lower end (not visible). That entire part could have been all steel, and the lower end tapped, but I did not have a 10 mm tap handy.
If anyone needs more detailed photos, holler. I'd be happy to oblige. The thing works very nicely, and with a little practice I know I will be able to eyeball a 14 gram load in the thing and let it run.
