Mogo, have you had the chance to check out an Achille yet? Now might be the time (over the end of the holidays?) - I am just looking into distilling again and I would love to interrogate you
Alchemist wrote:Well, a few days later and there is no subsequent leak. I will add a small addendum to the User's guide. False pressure. You have to release it after you open the boiler and introduce air. Both times now (start up, and a few days ago) I went WTF with 150 F water (as opposed to 200+) coming out. Air just doesn't have the heat capacity of steam.
cannonfodder wrote:The Achille does have a vacuum breaker in the cap. Over time I have had the same thing happen several times. It is quite annoying but thankfully it heats to temperature in moments. I wonder if that leak in the cap was actually the vacuum breaker sputtering.
Trisha wrote:That sip - and smile - makes it all worthwhile. . .
Thanks for the update! I have a few priorities on the dance card now, but I've been keeping an eye on the Achille in the hopes of seeing a few upgrades by Gaggia (that bend is worrisome).
sophiesbar wrote:Cannonfodder
This subject goes back a bit, but---
Did you dismantle the 'Safety cap assly' to make it function correctly, or did it come right?
Is it threaded left or right handed, or maybe 'Loctite'd on assembly. The rubber seal is not available as a spare.
I am finding the same thing is happening now. If the machine has been sitting overnight, a vacuum has formed in the boiler and on switching on the element makes a hell of a rumble until the steam valve is opened and bled.---Then it must be bled again after heating for a while, otherwise the boiler water does not reach the correct temperature even though the correct pressure has been acheived and switched off the element and the green indicator light.
I enquired with the N.Z. Gaggia agent, but they were less than helpful other than providing the cost of a new complete cap assly.
I presume you still use the Achille?
Thanks
