cannonfodder wrote:Once I got the first roast through it, it appears to have settled in. My only complaint is that I still end up with a lot of chaff in a dry processed bean. I just give the cooling tray a slight jiggle while blowing over the surface. On my home roaster, I used an air compressor to blow air up through a colander. The chaff would blow up and out as the beans cooled.
I hope this lasts for several years. I roasted one of my common blends, it will be interesting to see if I notice a difference in the flavor profile. Not having a temperature control is something I will have to adjust to. With my home made roaster, I could monitor the chamber temp and make fine adjustments to the heat. With this you just set it and go. While you can get the temp on the digital model, you can not make any adjustments.
Hey Dave,
Espresso and Home Roasting here on the eastern edge of the great prairie moves forward! I am sure you will love the Hottop. I got mine in July 03. In April 04 it developed a problem of not dumping beans when I hit the "eject" button. The Hottop people were good to their warranty and replaced that early model in July 04. I have been using the same since for 3 batches weekly.
Because I like darker roasts I always start with 225 g as opposed to the 250 max. I use a timer, starting at the end of the 30th beep telling me to add the beans after warmup. I watch and record times to first crack / second crack and dump. I decide when to dump almost entirely based on time relative to 2nd crack. Since I weigh the beans before and after roasts I can calculate % weight loss as a measure of roast level.
I find that dry-processed beans do indeed produce lots of chaff and like k7qz also use a ShopVac after each roast. Also like him I never clean my drum so it is a golden color. Once a month I remove the drum and clean inside more thoroughly. I also wash out my filter once a month.
k7qz, I read somewhere that one can buy the new digital panel and replace our old ones. I think Sweet Maria's even had a scratched one on sale. They had instructions for the replacement. I am not really tempted but might try it if mine fails.
I find I get really consistent results from this machine in its stock form
KS
