by cannonfodder on Mon May 01, 2006 8:35 pm
Evening GaggiaGirl.
As Jim points out, these machines (Factory and Pavoni) have a relatively noisy tip. It seams that the positioning of the holes in the tip and angle of the wand can be problematic. On my Factory, when two of the holes are dancing perfectly on the surface of the milk, the third is too high. It blows lots of bubbles. If the wand had more of a downward bend in it that third hole would not be quite as high.
I plugged the troublesome hole with a toothpick. Use a plain, brown, round toothpick. Just push it into the hole. Give it a little bit of a twist while working it in, and then break it off flush with the tip. That was the magic moment for me. After that it was a breeze.
Once you get the hang of it, you can push out the plug and go back to all three holes. I also find that keeping the tip barely submerged after the stretching (I stop at 80F) I get better agitation in the pitcher. I rarely go much deeper than just below the top of the steam tip and hold it close to the side of the pitcher.
You should be getting a subtle Pssst... fsssst... swwssst from the pitcher when you hit the sweet spot. Get the tip to high and it will sound more like a kid blowing bubbles in a cup through a straw. Yes, I know that is a silly analogy but it is pretty accurate. And practice, practice, practice, I use 2% milk, skim milk will froth easier but tends to make larger bubbles and whole milk produces less volume but makes a much finer and richer foam.
