Hello:
I fear (know?) that many of the forum members any will find this solution to Remodelista's problem rather drastic and even reckless, but it's worked for me in a great many ocassions. I started to do it (instead of rushing out to buy yet
another tool and a special, hard to find one at that) basically because I realised that
my equipment belongs to
me, that
I paid for it, so no manufacturer has the right to put in a security screw to keep me from getting inside it to do whatever I feel.
Like voiding the warranty, for example. =-D
After all, it's not really yours till you've taken it apart, right?
Remodelista wrote:I have the right size screw head but it can't get into the opening due to the pin ...
Here's how I have solved this problem with many appliances with these damn screws:
1. get a very small cheapo flat-head screwdriver.
2. check that you can fit it in between the pin and the sides of the hole
3. push it in to the bottom and slowly use the screwriver as a sort of a crowbar to bend the pin off centre.
4. repeat the operation from the opposite side.
5. repeat 3. and 4. again till the pin breaks off. It takes two or three times, no more. It is rather soft steel.
With the pin off, you can now unscrew the torx off with no problems. If you are very precise about these things, you can eventually dremel off (with the right bit, lots of care and patience) the little stub that remains at the bottom, but I have found that it is not really necessary.
Caveat: this worked for me because I've done it many times and in doing so acquired a certain practise. Maybe it was because either the gods were smiling upon me at the time, I'm very lucky or it was just a fluke. This does not mean that, even if you are as lucky as I am and even follow my instructions to the letter, it will work for you.
But I do hope you get it sorted out. =-)
Best regards,
CIV
