www.eccocaffe.com: custom coffee roasted in Northern Italian style
My cheap and easy stepless Rocky mod...
Link to "My cheap and easy stepless Rocky mod..."by TimEggers on Sun Feb 11, 2007 1:16 pm
*** NOTE: PLEASE SCROLL DOWN FOR THE LATEST DESIGN!!! (you know, the one WITHOUT THE UGLY C-CLAMP!!!) ***
Here it is (exciting huh?) how I cheaply and easily converted my Rocky Doserless into a stepless grinder.
Pros:
* Cheap
* Easy
* Effective
* 100% reversible
* Anyone can do it
Cons:
* Kinda ugly
I used a large clamp to gently squeeze the machine housing against the hopper making it hold the hopper. I did several tests and I don't see any grind drift or damage to the machine. I do want to add some cushion between the housing and the hopper just to soften that edge, but that shouldn't be a big deal. I can even adjust the hopper when the clamp is installed, it doesn't take much pressure to hold the hopper still. I also simply stuck a coffee bean between the housing and the spring loaded pin lever so it wouldn't lock into the hopper.
Take a look:
Note: Here I am using a large clamp because it's the only one that I had, a smaller less ugly clamp would work just as nicely...
Also since I have really liked the Rocky and it's ability to grind for espresso I was hesitant to upgrade to a stepless but now with this mod I have a stepless. And it didn't break the bank!
Tim
LMWDP #202
TimEggers
Link to "My cheap and easy stepless Rocky mod..."by oofnik on Sun Feb 11, 2007 3:00 pm
Hah.. well, whatever works! Sure it's ugly, but for some of us, it's just the function that counts :lol:
oofnik
Link to "My cheap and easy stepless Rocky mod..."by TimEggers on Sun Feb 11, 2007 3:26 pm
Well I'm going to make a more permanent and much better looking clamp system. What I am finding so far after several shots is that this approach really works nicely. Also a side benefit as it seems (and which I cannot confirm at this point) is the grind consistency seems improved. I can't explain it, but after this mod my shots are much better and the extraction is much more even.
My consistency has also gone up. I can't explain it other than perhaps his mod holds the burr more solid and doesn't allow minor grind drift. I can't find any other explanation to the noticeable improvement in my shot quality. I could see getting lucky on one or two shots, but every single shot this morning has been noticeable better and cleaner tasting than yesterday's shots and the only change is this mod.
I also can't believe the difference a half step makes. Sure the Rocky did a nice job when stepped, but now I can really tweak the grind and the results are outstanding. I finally have the Black Cat dialed in and man it's amazing. The chocolate is so much more pronounced. Truly a sublime shot of espresso.
Here's to success!
I'll post follow-ups after more experimentation and especially after my finalized clamp system. Please stay tuned!
Tim
LMWDP #202
TimEggers
Link to "My cheap and easy stepless Rocky mod..."by TimEggers on Sun Feb 11, 2007 9:44 pm
Well I employed a much simpler set-up:
I also padded the sharp metal edge with a split piece of clear plastic tubing, and for the clamping I am using two stainless steel pipe clamps. The big plus here is that it doesn't look nearly as bad as the huge c-clamp and it doesn't impede the other functionality of the Rocky (such as seeing the number dial). I am also pleased that I could achieve a stepless design at little cost, with an easy to implement mod that is completely reversible and of which should not damage the grinder or it's parts. Everything seems to be padded and covered, and I must say this mod works like a charm. Adjustments are made by simply turning the hopper with both hands. That works surprising well because since the hopper is always under a rigid hold it turns smoothly and even very small adjustments are easy (it's tough to overshoot in other words). The force needed to hold the hopper completely still during grinding is less that the force needed to adjust the hopper, so I can make adjustments on the fly without having to loosen the clamps, a big plus! It's great having a stepless Rocky Doserless.
Also as I mentioned above the big perk of this mod is the fact the hopper (and thus top burr) are held in a very rigid arrangement something I didn't see much in others mods. It seems (based on one days tests...about 9 doubles) that the grind seems to be even more uniform. The grind does not drift under load and I suspect that because the hopper is held so firmly (much more so than the standard spring loaded pin) that it results in a more rigid grinding system.
All I know is that my shots today blew me away with a noticeable better taste. Less bitters and a cleaner more defined flavor (it's really nice not having to use steps). Plus if I need to grind for drip I can simply loosen the pipe clamps and bam, I have a stock Rocky grinder!
I couldn't be happier with this set-up and I feel as if my need to upgrade just got pushed way back! Take a look:
Tim
LMWDP #202
TimEggers
Link to "My cheap and easy stepless Rocky mod..."by TimEggers on Mon Feb 12, 2007 12:23 am
Site is up with much more information and more pictures:
http://www.angelfire.com/pro2/pan...oserlessrocky.html
Tim
LMWDP #202
TimEggers
Link to "My cheap and easy stepless Rocky mod..."by Beezer on Mon Feb 12, 2007 2:40 pm
Cool mod, Tim! I might have to try it. Seems like a large cable tie could work too, or would that not clamp the hopper tight enough?
I'm not sure I can visualize how you blocked the spring loaded pin that normally keeps the hopper from spinning. You just wedged a coffee bean in there? Seems almost too easy...
Eli
Beezer
Link to "My cheap and easy stepless Rocky mod..."by TimEggers on Mon Feb 12, 2007 3:40 pm
Beezer wrote:Cool mod, Tim! I might have to try it. Seems like a large cable tie could work too, or would that not clamp the hopper tight enough?
Eli
I dunno a cable tie could work...haven't tried that. Yup the bean does the trick!
Tim
LMWDP #202
TimEggers
Link to "My cheap and easy stepless Rocky mod..."by Jasonian on Thu Mar 08, 2007 4:51 am
Reminds me of my own stepless mod for my MDF.
Simple resistance is all it takes to make a grinder stepless. Super cheap, and easily reversible.
Jasonian
Link to "My cheap and easy stepless Rocky mod..."by TimEggers on Thu Mar 08, 2007 11:05 am
Jasonian wrote:Simple resistance is all it takes to make a grinder stepless. Super cheap, and easily reversible.
Bingo.
Tim
LMWDP #202
TimEggers
Link to "My cheap and easy stepless Rocky mod..."by diab0lus on Tue Mar 27, 2007 12:18 am
TimEggers wrote:Site is up with much more information and more pictures:
Cool mod. I just did something similar to this on my Rocky where I put 3 or 4 layers of Teflon tape over the threads on the burr carrier (I think that is the right term) and I rolled up black electrical tape and wedged down the grind adjuster button. It takes only one hand to turn the hopper, but it is a fluid movement and the grind setting stays put. This solved two problems for me as well - eliminated the drift while grinding (previously I would hold the hopper while grinding - no fun on a dozerless Rocky) and now I can grind to 10.5 if i want (and my amp now goes to 11 :P ). I also noticed a better taste to the coffee when I was able to stabilize the hopper to keep the grind from drifting, which I did by hand for almost a year.
I would be interested to hear from people that have used both a stepless rocky and a stepless Macap M4 (or MC4) or Mazzer Mini (or Mini E) to see if it is still worth the upgrade after this easy mod. I know there are also other grinder factors to consider between these models - grind adjustment being only one of them. After hot rodding Silvia, I have been thinking about delegating Rocky to drip grind only and getting a Versalab... I mean Macap M4 or a <$500 second hand grinder and new burr set.
-Ryan
diab0lus
Why Stepless?
Link to "My cheap and easy stepless Rocky mod..."by BigFrank on Thu Mar 29, 2007 2:00 pm
What is a stepless grinder, and what are its advantages?
BigFrank
Link to "My cheap and easy stepless Rocky mod..."by TimEggers on Thu Mar 29, 2007 2:08 pm
BigFrank wrote:What is a stepless grinder, and what are its advantages?
A stepless grinder is one that will allow the adjustment of grind size to be any place on the dial, not a predetermined locking point. Stepless grinders offer the ability to adjust as much or as little as you like and leave the dial in any location, stepped grinders typically have click stop points (for example go from slot 12 to slot 13 but can't stop on 12.5).
Stepless offers the advantage of selecting any grind size. Sometimes in espresso making the smallest adjustment can alter the shot in significant ways. Also many (but not all) stepped grinders offer what some feel to be not fine enough adjustability. Some (and again not all) people have been frustrated because one point will be too coarse and the next available point finer is too fine. With stepless you could just stop somewhere between the two points and get the exact grind you like.
Tim
LMWDP #202
TimEggers
Ahhhhh
Link to "My cheap and easy stepless Rocky mod..."by BigFrank on Thu Mar 29, 2007 2:10 pm
I see.
The "step" part was throwing me. I would call that (non)discrete rather than stepless, but I understand now.
Thanks
BigFrank
Additional markings
Link to "My cheap and easy stepless Rocky mod..."by D-Caffa-nite on Fri Apr 13, 2007 10:52 pm
TimEggers wrote:Well I employed a much simpler set-up:
Thanks for the tip. The implementation was quick and smooth. I also taped additional markings on the dial.
D-Caffa-nite
Link to "My cheap and easy stepless Rocky mod..."by TimEggers on Sat Apr 14, 2007 12:43 am
Wow. Nicely done!
Tim
LMWDP #202
TimEggers
Link to "My cheap and easy stepless Rocky mod..."by DC on Wed Jun 06, 2007 4:28 am
Tim,
I have copied your mod and found that, at any one grind setting, the Rocky now grinds finer than it did before. Did you find this, or is what I am witnessing just an effect of less movement of the hopper during grinding?
For example, with collar I use 11.5, without I use 10.
Doesn't bother me, I was just interested to know.
Thanks,
Dave
DC
Link to "My cheap and easy stepless Rocky mod..."by TimEggers on Wed Jun 06, 2007 9:19 am
Hi Dave,
As I recall I had to tweak my grind too, but it wasn't an awful lot. I suppose it could be due to a more stable grinding environment lending itself towards more uniform ground particles.
Tim
LMWDP #202
TimEggers
Link to "My cheap and easy stepless Rocky mod..."by neohk on Thu Jun 14, 2007 8:53 am
Hi. It's really impressive for you to think of such a convenient mod :)
i've got a question on the mod, would this mod affect the easy of cleaning the burrs? thanks in advance
neohk
Link to "My cheap and easy stepless Rocky mod..."by TimEggers on Thu Jun 14, 2007 11:04 am
No, it shouldn't affect it too much, simply loosen the clamps and remove the hopper as usual.
Tim
LMWDP #202
TimEggers
Link to "My cheap and easy stepless Rocky mod..."by psycho_supreme on Thu Jun 14, 2007 7:20 pm
hey Tim, a fellow CGer!
I love this mod, I checked it out while I was looking at your can roaster to investigate for myself.
-Matt
psycho_supreme
Next
Return to Espresso Grinders
