Intro:
I preface this report with the caveat that I have only used this adaptor for one day and never with coffee in a PF. Yesterday I ran tens of measurements on my Andreja Premium (25-second, 60ml shots), comparing Greg Scace's Thermofilter to EricS's adaptor. Most of the shots, except for a few to check out the initial flush, were a simulation of my daily routine: (1) After an initial warmup of about an hour, flush about 4 ounces and almost immediately, pull the first shot. (2) Right after the shot, another two short flushes to clean the showerhead first without and then with a brush. (3) Then a 4-minute wait while I prepare the next shot (without the PF, or in this case without the Thermofilter locked in place). (4) Lock and load and pull the next shot. (5) repeat from (2) on.
The only changes I made to the above routine was to vary the waiting time between shots to see what influence it would have on the shape of the two curves generated and on their relationship to one another.
Comments:
Eric's instructions are very detailed and generally excellent. There are a few small points that I would expand slightly but unless you have the adaptor, they're of no interest here so I'll pass them on to Eric in an email. But for those of you with an Andreja, the distance from the seat of the M6 allen-head capscrew plus the crushed copper washer, to the point of measurement for the TC probe tip was 0.630". It will no doubt be different on other machines. Eric calls this "the adjusted value of D". At this length, the probe tip is just slightly into the intersection where the water takes a 90-degree turn on its way to the showerhead.
As Eric has already noted, the Omega HTTC probe has very fine wire attached and I'm now trying to figure out how to apply some strain relief to keep it from breaking. But in general, the accuracy (checked against a lab standard) and the response time is amazing. If I put the probe tip between my fingers, it goes to temperature in less than a second and immediately stabilizes there. So I guess it's a toss-up between fragility and function.
The adaptor fit perfectly on the Andreja (as opposed to another user's experience with, I suppose, another type of machine) and Eric's "paperclip method" of determining the correct point for the tip position, worked just fine.
Observations:
It appears, looking at my data and the generated curves where I recorded both temperatures (T1 and T2) and the difference between them (T1-T2), that no matter how long I wait between shots, anywhere from 1 to 5 minutes, the shape of the two curves and their temperature relationship to one another varies very little. At the beginning of the shot they are about 5 deg F apart at the point just after the initial buildup to maximum temperature and converge to less than 1 deg F at the end.
Actually, this is good news because, using the adaptor for a flushing guide (its primary purpose for me), I can be relatively certain that if, I flush the machine until the I'm about 5 to 6 deg F above my intended "starting temperature", I can quite accurately predict the temperature level and profile of the entire shot, given that the Andreja holds the shot to within a 2-degree F range from the maximum temperature at the beginning of the shot, to the minimum temperature at the end. Again this is only after one day of use and I didn't play very much with flushing routines vs. time between shots to attempt to change the shape of the temperature profile. The profile illustrated is the one I use for my daily drinks.
The curve that I have posted is very typical of all the curves generated yesterday. The main difference between them is the temperature on the Y axis. I could almost go to the graph and change the values (within a reasonable range) and the curves would look the same. I said "almost". But again, what this tells me is that the adaptor can be a valuable tool for judging how much (or long) to flush and also gives some usable information about the shot temperature because at the end of the shot, the two temperatures converge.
BTW, it may seem, looking at this curve, that there's a huge difference in temperature between the two devices. But consider the fact that the temperature range (axis) is very small - only about 15 degrees F so the distance between the temperatures seems exaggerated. The difference between the two, when the shot is at its maximum point in the Thermofilter is only about 4.5 deg F.
So far I'm a happy camper!
BobY
