HB wrote:Something is not right. Either the pump is not working correctly, or the HX is so full of scale that it's obstructed. Below is the flow rate charts for a Ulka vibration pump:
OK. Thanks for the facts. When I first got the machine, my cleanout included the "mushroom", which did indeed have a ton of crud--not scale, per se, (like calcium), but hard minerals.
I cleaned that all out and got reasonable flow (but not the levels in the chart). But before that, I pumped vinegar through the unit for several hours to descale any calcium buildup.
I suspect that from all my opening, cleaning, shaking and scrubbing, there is still stuff floating around in the system.
I do note now, that when I turn on the pump, very little flow is apparent but water is coming out the silicone drain pipe into the tray. That comes from the main brass "block" thing, which also seems to feed the HX with water.
I'm betting I still have sludge in there perhaps.
