Jasonian wrote:I'm in the market, but I'm not convinced by initial hype.
And you shouldn't be. Skepticism is a Good Thing. My comparisons are flawed because it's unfair to compare the new Duranium burrs to my used Mazzer burrs. Furthermore, with only one SJ grinder on my counter, it should be obvious that I cannot perform any scientifically valid taste comparisons. I've only had these burrs for a couple of days, and I'm going out on a limb by recommending them.
But I'm reasonably comfortable posting my positive first impressions of this new burr set for several reasons. Michael Teahan (a true espresso luminary) gave the Duranium burr set his blessing when I contacted him offline. My observations thus far reinforce his comments about the faster grinding speed. The taste profile is similar to the standard Mazzer burr set, but I'd rate the Duranium pours slightly better. This could be due to burr sharpness. In his new book, Scott Rao states emphatically (p.7) that
The single most important feature of a grinder is sharp burrs.
According to Michael Teahan, the Duranium burrs are significantly sharper and harder than the standard Mazzer burrs, so they should stay sharper over time, as well as lasting longer.
Finally, the small cost differential between the Mazzer burrs and the Duranium burrs (under $30) makes this a relatively low risk purchase. I'd be much more cautious about recommending a $1K+ grinder after just a few pours!
I'm also eager to see more reports on this new burr set. But I'm predicting we've got a winner.
EDIT: Due to grinder stalling issues, I must retract this statement. See my followup posts on this thread for details.
