kwksilver wrote:Their internal component quality is complete overkill. Truly fantastic. Like a Merc from the 70's.
I would say that this is a fairly accurate description of the Mahlkönig's build. It is impeccable. The best build and finish of any coffee related component I have ever owned or used.
As for the grind, I have owned several grinders and in terms of the results in the cup I would put them in the following order:
1. Compak K10 WBC (conical burr)
2. Mahlkönig K30 Vario (flat burr)
3. Casadio Instantaneo (conical burr)
4. Mazzer Mini-E / Mazzer Mini doser (flat burr)
5. Rancilio Rocky Doserless (flat burr)
There are some additional caveats and observations, though:
As has been said, the Mahlkönig is exceptionally fast. It is also the quietest grinder I have ever used. The portafilter rest and the stepless adjustment are absolutely great. The timers are also surprisingly accurate. There is some coffee retained in the chute and the chute is almost impossible to clear manually, so one just has to purge some coffee in the beginning of each session - the amount is smaller than with the Compak or the Casadio but bigger than with the Mazzer or the Rocky. As is typical for a flat burr (in my experience), an even naked extraction is more difficult to achieve than with a conical grinder. However, the Mahlkönig is better than the other flat burr grinders in this respect. There is some clumping in certain conditions and with certain coffees, but the clumps appear to be fairly soft and redistribute fairly easily. I am very happy with the shots I have pulled with this grinder.
The Compak produces a great grind. Perfect extraction is dead easy to achieve, the shots go blonder later into the extraction and they taste that little bit sweeter. It is almost impossible to achieve an extraction as good as this with a flat burr grinder. However, the Compak is huge not only in its outer dimensions, but also internally. The grinding chamber and the chute are voluminous and hold a lot of coffee - this results in a lot of wasted coffee even if you brush out the grinds from the chute after each session or shot. The size of things also results in timers not being very effective on this grinder and achieving accurately repeatable dose sizes is a lot more difficult than e.g. with the Mahlkönig (or Mazzer for that matter).
The Casadio is built like crap and is ugly as hell. The grind adjustment is via a worm drive that is too accurate in my opinion (a lot of coffee wasted when dialing in a new coffee). There is no portafilter holder, continuous grind button or grind activation by the portafilter. I did not learn to like the taste of the coffee this grinder produces - it was overly bright with bitter tones. However, the Casadio did produce a great fluffy grind and it was even easier to achieve a perfect extraction with it than the Compak. This aspect was as close to perfect I have seen in any grinder, but the downsides and the taste were too much for me to take.
Of the Mazzer's I did not particularly like the Mini-E's timer adjustment mechanism or the portafilter fork, but main reason for moving on from the Mini-E were the grind particle size sorting issues I was experiencing. The doser version of the Mini was better in this respect, although a bit slower in grind, but I just do not like dosers (one of the reasons I gave up the Compak in the end).
The Rocky was a good grinder. The Mazzer's were not a huge improvement in grind quality / taste in the cup, but they were built better, had stepless adjustment and ground a bit faster.
Is my grinder journey finished? Never say never. I may get a Versalab as a second grinder one day, but I am currently quite happy with the Mahlkönig. My wife loves it for the looks as well as the easy usability.
Br,
Teme
